No oil pressure, think i tried just about everything...
The sensor reads 99 when it doesn't get a signal, its an intellitronix cluster. When its connected to the sender its doesn't change, still reads 99, doesn't even blip. If i ground the wire to the housing of the sender or the block it drops to 0, so i know the ground on the sensor is good. I tried first with the factory sender, then even bought the intellitronix sender, but it still does the same thing.
Oil pressure
You should try running it with the sender grounded, the gauge I have reads zero until the engine is running. It has a single wire going from the sending unit to the gauge. When I installed it I only put Teflon on the first few threads of the adapter/sending unit so I could get a proper ground, you should try hose clamping a ground wire onto the sending unit and see if you get a reading.
