What would Installing the Crankshaft timing gear with a deadblow hammer damage?
I have had several duh moments lately...
I was putting my new timing set on tonight and did not have a longer crank bolt handy, so I used a deadblow (plastic mallet) to install my lower timing sprocket on the crank.
Took quite a few good licks. Motor seems harder to turn over now by hand... (It's just the assembled shortblock, crank rods and pistons. Timing chain is not on.)
Last week I could mostly spin it by using two hands on the crank, now I can do that about half the rotation, but it seems to hang ever so slightly. Spins ok with a wrench.
Am I just being paranoid?
What should I check for damage? Main or Thrust bearings?
