Improved Racing Crank Scrapers
#221
LS1Tech Sponsor
Yes, you'll get the new version. EGM-730AF is for ARP main studs. If you have factory main studs, you want part number EGM-730F.
#226
LS1Tech Sponsor
http://www.improvedracing.com/crank-...kit-p-648.html
So you HAVE to have ARP main studs to run this?
But if there are enough requests we will make a version for the factory studs as well. We were just trying to minimize how many different scrapers we are making on the first batch since we have so many versions.
#230
LS1Tech Sponsor
LS1Tech Sponsor
What oil pans do you guys have? F-Body?
The part numbers will follow the same structure as the 4" stroke parts, except the second number digit will be a 3 instead of a 4.
Post up what you have so we can figure out what to make next.
#234
We don't have one for the factory stroke with aftermarket rods yet. We are working on them though and will start making those versions soon.
I have a fbody pan with lunati h beam rods, can get measurements if you need them. If you make one I will be your first customer. Thanks!
#235
LS1Tech Sponsor
LS1Tech Sponsor
As long as the instructions provided with the ARP stud kit are followed, there shouldn't be complications. If however, all of your questions/concerns are not answered by reading the manual, we recommend contacting ARP for more information on this matter.
#239
LS1Tech Sponsor
Absolutely, just give us a call and we will help you out. You can also just order the individual components you need instead of the baffled pan kit.
