Anyone have proof that a long stroke makes torque?
Old Jan 25, 2014 | 06:05 AM
  #101
TT427's Avatar
This isn't about what's plentiful, cubes ultimately determine the tq/hp, then things like compression, induction, cam events determine the shape and curve. You don't see big bore short stroke on the street because of expense. In racing valve curtain generally means more than displacement because it's usually limited, so you turn it higher, means you need more head flow. More head flow comes from bigger bore and bigger valve. The rpms in a street deal never tax said engine in normal driving. That's why I suggest the ls3 build, more cubes than you say you need, bigger bore for the ls3 style heads though for what you are doing a cathedral is probably the better choice (and makes the bigger bore not needed 4.0 is plenty) and use a good 3.9 or 4.0 stoke crank and still use a good rod. You said it, displacement always wins in NA.... No one in their right mind limits the max cubes that a budget can afford...
Old Jan 26, 2014 | 07:05 PM
  #102
kelobro's Avatar
Oddly enough, I stumbled across an off-the-shelf combination that looks like it would work to make a short stroke. long rod 350 with a rod/stroke ratio of 2:1.
LSX block bored to 4.125
Stock 4.8L crankshaft with 3.27 stroke
Eagle 6.560 inch long H-beam rods (.927 pin)
Mahle pistons with 1.045 compression height (4.125 bore, .927 pin)
Yields 11.88:1 compression with 64cc heads & .045 head gasket
Yields 11.43:1 compression with 64cc heads & .058 head gasket
Yields 10.97:1 compression with 70cc heads & .045 head gasket
Yields 10.59:1 compression with 70cc heads & .058 head gasket
Old Jan 27, 2014 | 08:17 PM
  #103
A.R. Shale Targa's Avatar
If the custom Wisecos aren't too much more, you may want to get a taller piston which adds bore stability(on directional change) and lessens the
chances of ring flutter. Guys like Joe Sherman and even Bill "Grumpy"
Jenkins found that the rod/stroke ratio never really mattered much from a
power standpoint. Obviously the piston gets lighter but the rod gets heavier.
Definitely a law of diminishing returns. Ring seal is everything for NA apps.
IIWY I'd run a 1.5 C.H. piston (Wiseco with the thermal top coating and the
anti-friction skirt coating); with a 6.125" rod the piston would be at 9.26".
Popping out of the 9.24" deck by .020" would put the quench at .040 by
running the .058" gaskets.
Old Nov 22, 2014 | 07:16 PM
  #104
curtis73's Avatar
I'm going to toss my hat into the ring.
Long stroke does not make more torque by itself. Increasing stroke (thereby increasing cubes) does increase torque, but for the same displacement, power/torque output will be almost identical.
Compare for example an Olds 455 (4.126 x 4.25) versus a Buick 455 (4.313 x 3.9). Equipped with the same head flow, cam timing, compression, etc, they will both have nearly identical tq and hp outputs at the same RPMs. The big difference in the two is peak potential. Getting the Olds to breathe with the small bores, and getting it to spin fast with the long stroke are an issue.
It doesn't matter that the Olds has a longer stroke, it still has the same torque output at the same RPM when all other factors are the same.
Old Jan 15, 2015 | 03:40 AM
  #105
kelobro's Avatar
Default Compromised
I got sick, nearly lost job. Had to face the fact that I don't have the time or ability to do any of the work myself, not even the install. Settled on a budget build from Thompson Motorsports. 5.7L 355HP. It was great to work through the details with Kyle Thompson. Awesome service. I'll post an update once the truck is done and broken in.
The 5.7 will run on the 5.3L stock tune, but needs a real tune to wake it up. I'll provide subjective before/after comments on the experience.
If circumstances ever change, I'll start with a G8 with a 6 speed, then try the LSX based build. Who knows, something better may be available by then.
Old Jan 15, 2015 | 03:42 AM
  #106
kelobro's Avatar
Good info Curtis, thanks.
Old Jan 16, 2015 | 02:44 PM
  #107
Kip Fabre's Avatar
Everything being the same this is true. Most of the time the longer stroke engine has a shorter rod so the rod ratio is less and that is what make more torque at lower rpms not the stroke. So the (Olds 4.126 X 4.25) has a 6.0 rod Versus the (Buick 455 4.313 X 3.9) with a 6.0 rod. The olds will have more low end torque because it has a 1.41 rod ratio wile the Buick has a 1.53rod ratio.
Old Jan 16, 2015 | 03:11 PM
  #108
96capricemgr's Avatar
Not buying the different 455s analogy, not a valid comparison unless the basic engine architecture is the same. Don't care if static head flow on a bench is similar.
Old Jan 16, 2015 | 03:26 PM
  #109
Kip Fabre's Avatar
OK then just play like they are the same engine Olds or Buick but different bore stroke and rod but same cubic inches.
Old Jan 16, 2015 | 04:23 PM
  #110
My reply was more aimed at curtis rather than you, I should have quoted him to make that more clear.
Old Jan 16, 2015 | 07:51 PM
  #111
Kip Fabre's Avatar
Sorry about that. Then you are correct.
Old Jan 17, 2015 | 07:56 PM
  #112
kelobro's Avatar
Well, when someone pays Thompson Motorsports to make a big bore version of the motor I just bought we'll know. Until then it's all theory and BS.
Old Jan 17, 2015 | 09:13 PM
  #113
formulaon18s's Avatar
I only skimmed, but if building a max torque truck motor and already factoring LSX block purchase, why not go with Max ci 45X" and small duration cam. It would make more power <4000rpm than any 350" motor regardless of bore/stroke combo.
Or build a stout budget 6.0 with a stock iron block, small cam and positive displacement blower on top. 3000rpm with 10lbs of boost will make big torque to pull up a steep grade. At any rate a motor built with no intentions of going above 5500-6000rpm don't need all the high dollar pricy parts most guys seek who are wanting a reliable 7500rpm
Old Jan 18, 2015 | 02:17 AM
  #114
The 4.8 and 5.3l motors are the same other than the stroke and rod length, not the exact test you want but a simply observed example of what stroke does for power.
Same intake, cam, heads, exhaust, etc. just because you don't like the example doesn't make it wrong.
Old Jan 18, 2015 | 06:49 PM
  #115
kelobro's Avatar
It's a wrong example because the cubic inches changed when the stroke changed. The only way to tell if torque is produced through stroke is to change the bore/stroke and leave everything else including the cubic inches the same. Your example is less valid than the Olds vs Buick one above.
  #116
kelobro's Avatar
That wouldn't answer the question...
Old Jan 18, 2015 | 07:18 PM
  #117
Kip Fabre's Avatar
I will answer the original question.
Anyone have proof that a long stroke makes more torque?
If you have two engines both are 351 cubic inches. The one with the lower rod ratio 1.5 rr will make more torque even if the stroke is shorter at the lower rpm range than a longer stroke with a 1.6 rr.
Old Jan 18, 2015 | 10:19 PM
  #118
perhaps a comparison that might show your point would be the mid to late seventies era (smog) 400 cubic inch engines. I mean Buick and Olds had versions in the mid sixties but they had much higher compression ratios.
Sticking with the 70s stuff compares all the 400 lift, 8 to one compression, with crap cylinder heads; most of which struggled to make even 200 horse.
Chevy was 4.125" X 3.75" with a 5.565" rod length 1.48 rod to stroke ratio
Pontiac was 4.125" X 3.75" with IIRC 6.63" long rod
Ford 400M was 4' X 4" and I think a 6.59" rod
Mopar was 4.342" X 3.38" with a 6.358" rod
Olds 403 not too sure 4.36" X 3.38"..maybe ?? long rods for sure
Ford's M engine probably had the best of the junk heads (canted style)
Olds and Poncho had flatter valve angles and 30 degree seats which promote low lift flow...but the ports were terrible
Chevy and Mopar heads were complete garbage....similar with small ports and valves
Old Nov 28, 2017 | 12:12 AM
  #119
kingtal0n's Avatar
Lol, the definition of torque or moment about any point in a plane axis is force times the perpendicular distance or length...
i.e. if we set stroke to zero, torque = zero because any number times zero is zero, there would be no torque
Old Nov 28, 2017 | 12:25 AM
  #120
So now we know, you know the definition of torque. And that contributed to this thread, HOW??
