224/224/112 numbers
Old Jan 18, 2014 | 06:15 AM
nascarnate326's Avatar
Default 224/224/112 numbers
What should the average M6 224/224/112 car be making for power?
I have seen lots of high and low numbers but not a consensus on whats normal for this cam.
Going to get my car dyno'd this year and was wondering where I should fall at.
Does headwork make that big of a difference with smaller cam's?
Old Jan 18, 2014 | 02:13 PM
anyone?
Old Jan 18, 2014 | 02:29 PM
DREAMZ28's Avatar
Don't know numbers but heads help even on a stock cam. It'll flow more air at all lifts, not just at .600+.
Old Jan 18, 2014 | 03:54 PM
red fury's Avatar
My 01 m6 made 388/379 sae corrected on a dyno jet. That was with a stock rear with 4.10 gears. That was cam only full exhaust motor back. TR224/224 .563/.563 112lsa.
Old Jan 18, 2014 | 04:04 PM
01ws6m6conv's Avatar
mine did 396 rwhp with long tube headers and a k&n filter and slp lid on a dynojet. ls1
Old Jan 18, 2014 | 04:12 PM
99Bluz28's Avatar
A good set heads will make a big difference, especially if the SCR is raised at least a full point.
Old Jan 19, 2014 | 07:05 AM
So 375-400 is normal?
Old Jan 20, 2014 | 07:02 PM
janaka's Avatar
I was 378 or so with shorty headers on my swap, stock heads
Old Jan 21, 2014 | 10:15 AM
parnlyp1's Avatar
385/362 M6
Stock heads, full exhaust. 12 bolt with 4.11's LS6 intake
Old Jan 21, 2014 | 10:28 AM
TImmy_Jones's Avatar
Also depends on the dyno and weather (I know it goes without saying).
I would estimate between 375-395
Old Jan 23, 2014 | 05:12 AM
Mine was good for 12.50`s in 85-90 degree heat,stock heads,3.73 gear,with the LS1(before the motor swap)
Old Jan 23, 2014 | 08:30 AM
David@Vengeance's Avatar
In a M6 car, 380-390 will not be an issue with that cam. Add some heads and a ported FAST 92mm, and you will be well into the 400's.
Old Jan 23, 2014 | 09:00 AM
jsteele90's Avatar
383/372 stalled auto. 11.90s@112
Old Jan 25, 2014 | 04:46 PM
thanks guys. It ran pretty good last year and now that I have a real exhaust with some flow I hope to get as close to 400 as possible.
this was last year
Old Jan 25, 2014 | 06:51 PM
MikeWS6's Avatar
It also depends on which stock castings are being used, as the 241s are superior. 224 with 241 heads should be around 380 to 400. 224 cam with stock 806 or 853 heads will be closer to 360 to 380 on an m6 car.
My car did 368/362 cam only with 806 heads
Then did 414/387 with the tsp 5.3 heads
Old Jan 25, 2014 | 07:53 PM
7SEALS's Avatar
this was last year
1998 Camaro Z28 - YouTube
I gotta ask you, does that plate actually work? I had the idea of doing WVWWVW to throw off the cops, im assuming you have it for the same reason?
Old Jan 26, 2014 | 06:56 AM
All they do is **** cops off. I am in police cars often, and it's not the back seat if you catch my drift...
If anything it throws off the general public calling your careless driving into 911. In my area "a red camaro with 5'S for a license plate"....everyone knows who that is.
It's more of an attention getter IMO. In michigan it's getting more difficult to get plates like this, I tried several combos before SOS let me have that one.
Old Jan 26, 2014 | 07:26 AM
R6cowboy's Avatar
The 241 and 853 are identical heads. The only difference was the casting process which had very minimal difference in performance.
Old Jan 26, 2014 | 02:03 PM
2000RATA's Avatar
Exactly!
