ls1 with piston pitting
Old Jan 18, 2014 | 06:21 AM
vyls1wa's Avatar
Default ls1 with piston pitting
Hi there
Just looking for some points of view on what steps I should take with this wonderful picture I have below.
It's something I found today after cleaning all the carbon off the pistons for a new cam and head install.
It's only on one piston and know it's from Pinging, some of the high n low spot are up to 1mm.
What I'm looking for is are you guys under the impression of a rebuild or wet n dry the piston and install the new heads, I dont want to risk the gear I've just bought, I will stroke it latter in, but wasn't expecting to spend that money now.
Thanks
Old Jan 19, 2014 | 06:01 AM
vyls1wa's Avatar
Bump,
Sorry to be a pain but really after some. People's opinions on this.
Old Jan 19, 2014 | 09:19 AM
Krom's Avatar
IMHO it doesn't look like deto to me, that looks like debris went through the engine, what does the head, and cylinder wall look like?
You can sand the sharp spots off and run it
Old Jan 19, 2014 | 09:25 AM
crazyelf's Avatar
Its fine, I wouldn't think twice about running it how it is.
Old Jan 19, 2014 | 09:53 AM
vyls1wa's Avatar
Head was exactly the same mirrored, but only on the flat surface of the head, you can also make out the shape of that part of the head on the piston.
Old Jan 19, 2014 | 10:15 AM
.boB's Avatar
A sort of agree. If it's detonation from too much timing or compression, it's pretty severe. But then you would see it in more than cylinder.
OTOH, if the cylinder goes lean or the plug gets too hot, you'll get that in only one cylinder.
Unless you're racing, I'd smooth that out and put it back together. But I'd also be looking at other components to find out why that happened.
Old Jan 19, 2014 | 11:30 AM
jmargo's Avatar
Looks like a little debris went through. Make sure to check the valve seats. Whatever went through had a good chance to have been grabbed as the valve moved. Get the head surfaced, smooth down the piston and run it.
Old Jan 19, 2014 | 03:05 PM
vyls1wa's Avatar
That's the thing, I mainly use it for the drags now, I was going to get that injector testes aswell, I also though the damage may of been down some time ago.
So ok for the drags?
Old Jan 19, 2014 | 03:34 PM
A.R. Shale Targa's Avatar
Originally Posted by krom
imho it doesn't look like deto to me, that looks like debris went through the engine,
you can sand the sharp spots off and run it
this ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Jan 19, 2014 | 08:28 PM
RockinWs6's Avatar
That's not from detonation....something sat there getting whacked. Live near the Sopranos?
