Coil pack sides
Old Jan 21, 2014 | 12:03 AM
baronsmith98's Avatar
Default Coil pack sides
Made a stupid mistake and got my coil packs mixed up between driver and passenger side. Do they have to be on their designated side or does it not matter?
Old Jan 21, 2014 | 12:11 AM
Burken01's Avatar
What year car?
Old Jan 21, 2014 | 12:16 AM
Motor is out of an 02 Denali it's an lq4
Old Jan 21, 2014 | 12:20 AM
Undertow74's Avatar
just bolt them on up
Old Jan 21, 2014 | 12:23 AM
Burken01's Avatar
I know 98's have a certain way, not sure on other years
Old Jan 21, 2014 | 02:42 AM
ls1 1990 VN's Avatar
A coil is a coil.
Old Jan 21, 2014 | 06:36 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Coil packs, their brackets and wires are freely interchangeable.
Old Jan 21, 2014 | 08:48 AM
1fastls1ss's Avatar
As long as you didn't unplug the wire pack from the coils you will be fine. My last build I unplugged the coils from the wire pack to clean them up. Then put them back on the car, but accidentally flipped one wire pack over when plugging the coils back in. This caused the firing order on that side to be reversed. There is a specific signal wire on each plug to the coil. A write up here on tech I had found showed which color signal wire went to which cylinder.
Old Jan 21, 2014 | 01:57 PM
Thanks ill try to find that. I know they are on the right bracket just don't know which side
Old Jan 21, 2014 | 09:47 PM
Paul Bell's Avatar
I don't understand the confusion-or advice given in this thread. The plugs on the coil wiring harness on the bracket will exactly reach it's designated coil plug. If this coil wire is too long or too short, you're attempting to put it on the wrong coil location.
The entire coil assembly (bracket, harness & four coils) will freely swap to either side of the engine. The individual coils are identical and will work on any cylinder.
Old Jan 21, 2014 | 10:26 PM
I understand a coil will work on any bracket and any cylinder and i have them wired up correctly. What im asking is if i have the passenger on the drivers side and the drivers on the passenger side is each coil bracket wired to a specific side of the motor for its firing order.
Old Jan 21, 2014 | 10:47 PM
Paul Bell's Avatar
Third time's a charm?
Old Jan 22, 2014 | 12:40 AM
Are you asking more about the bracket & its wiring connector
Old Jan 22, 2014 | 01:55 AM
I may not be clear with the way im asking it but you either dont understand or have no FN clue what im asking. 1Fastls1ss answered it so thanks
Old Jan 22, 2014 | 10:10 AM
1fastls1ss's Avatar
Here is what I found on tech that helped me out greatly.
https://ls1tech.com/forums/generatio...ck-wiring.html
Paul your info in this thread helped me out so THANK YOU! I have a 98 so my coils had bolted onto the valve cover and when I unplugged them to clean them (before putting them on my new 99 and up brackets/valve covers for my 241 heads) I accidentally flipped the wiring on the passenger side. So instead of 1,3,5,7...it was reversed 7,5,3,1.
Baron if you left the coils on the bracket exactly like Paul pictured and only unplugged the big white plug (and left the smaller plugs on the coils) then yes the passenger side will work on the driver side. Just look at "C" on the plug that goes to the coil, that is going to be the signal wire for each cylinder. As long as you have this you will be fine:
1- purple, 3- light blue, 5-green, 7-red
2- red, 4- green, 6- light blue, 8- purple
Old Jan 22, 2014 | 12:14 PM
Paul Bell's Avatar
Yep. that works.
