Difference between the 5.3 and 5.7
Old Jan 28, 2014 | 04:59 PM
JSlayman22's Avatar
Default Difference between the 5.3 and 5.7
What is the difference between the engines as far as a swap? I have a 02 camaro I'm thinking of doing the swap and adding boost mostly because the ls1 in it is blown up and I'd like to do a boost build anyway so noes the time. What would be a good setup and what would I need to swap/ change around to make the 5.3 work before the boost?
Old Jan 29, 2014 | 11:51 AM
JustAFooL's Avatar
Lots of people throw boost on a stock 5.3 with great success. Head over to the FI section and you'll get more answers there in the stickies.
Old Jan 29, 2014 | 12:00 PM
Rise of the Phoenix's Avatar
Should be a pretty straight forward swap. Mounts right in place of the LS1.
Old Jan 29, 2014 | 01:11 PM
93Z2871805's Avatar
Veteran: Air Force
Besides drilling the bolt hole in the driver's side ear for the alternator bracket, it's a bolt in deal.
Old Jan 30, 2014 | 05:45 PM
Bilster's Avatar
Going to state the obvious but don't use the 5.3 MAF...it's different. You're going to have to bolt on the LS1 style intake unless you are going to run a hood scoop which also means LS1 style injectors. 5.3s have a different electrical plug in. Internally, the 5.3 has a smaller cam and a smaller bore. AND you're going to have to live with 88 more pounds on the front end if it's an iron 5.3.
Old Feb 2, 2014 | 11:15 AM
JSlayman22's Avatar
Thanks for your help
