Head decision...
Old Feb 4, 2014 | 09:53 PM
01 blue bullitt's Avatar
As did I with Landspeed heads, my current setup makes 447 through a a4
Old Feb 5, 2014 | 12:23 AM
Lowmiles's Avatar
You could go with the tfs 205s, they make about 11.5:1 compression have better ptv that stock heads, and flow great. Only downfall is you have to buy rockers for them to work.
Old Feb 5, 2014 | 05:26 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
There's a set of AFR 205's in the classifieds right now for 1500 shipped...
Old Feb 5, 2014 | 02:48 PM
ragtopz28's Avatar
Thanks Doc,
Actually there are a lot of 205's on there. Any reason why so many are getting rid of em?
Old Feb 5, 2014 | 04:11 PM
Originally Posted by ragtopz28
Thanks Doc,
My guess is going larger. A lot of people switch setups yearly. Plus tax time is here.
Old Feb 5, 2014 | 08:03 PM
z-maro's Avatar
OK narrowed it down to #1 or #4. What ya'll think?? They are within $100 of each other.
Anyone know the expected CR on #1 with the ".010-.015" surface milling?
I have seen a lot of positive results from AI here in the dyno section, and will almost certainly go to them for head porting if/when I get a head & cam combo.
Why do you need the AI HCR's? It is my understanding that they are only beneficial when you can not achieve a high enough CR with milling and a thinner head gasket due to PTV clearances. Maybe that is the case with the CR you are looking for, and the cam you are running.
Old Feb 5, 2014 | 10:21 PM
DREAMZ28's Avatar
From what I've read, milling decreases flow, so if you can keep the same flow plus higher compression, its a win win. Not sure if that's accurate though
Old Feb 10, 2014 | 04:39 PM
ragtopz28's Avatar
Anybody else? I went with______heads and gained xx at track or xx hp with heads only.
Old Feb 13, 2014 | 02:50 PM
ragtopz28's Avatar
Nobody??
Old Feb 13, 2014 | 04:21 PM
TXZ28LS1's Avatar
I just purchased livernois motorsports stage 3 LS6 heads.
Old Feb 13, 2014 | 04:38 PM
ragtopz28's Avatar
What performance gain do you think is between the stage 2 & 3? Looks like bigger valves and SS is the only diff.
