Need Lifter Suggestions For Vindicator Cam
Old Feb 2, 2014 | 01:20 PM
technical's Avatar
Default Need Lifter Suggestions For Vindicator Cam
I'm trying to get done a heads/cam swap. After inspecting my stock lifters I decided against re-installing them. The rollers had some pitting. Now I can't decide which lifters to buy. I see lots of recommendations for Morels and/or Lunati, but I don't know what makes the most sense for this cam: 240/244 .608/.596. I'm going to be using stock rockers with the trunion upgrade. The car spends more time on the street than the track.
I'm looking at either: comp 850, Brian Tooley SLRs, or maybe Morel 5206. Am I missing any other good options?
Old Feb 3, 2014 | 10:02 AM
lmt0705's Avatar
Good Old Ls7 Lifters In My Motor
Old Feb 3, 2014 | 10:16 AM
Jimbo1367's Avatar
BTR's SLRs
Old Feb 3, 2014 | 10:23 AM
97camaro383's Avatar
I have ls7s from SDPC in my motor but I'll probably go with the BTR slr lifters next time, just to keep everything quiet. Either way you'll be fine IMO.
Old Feb 3, 2014 | 10:27 AM
Baconz28's Avatar
My btr lifters go be here tomorrow. They starting to become popular for a reason.
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
LS7 lifters will do just fine!
Old Feb 4, 2014 | 03:38 PM
smws6ta's Avatar
FYI the preload on those lifters are 0.50" not the 0.075" that GM lifters usually have.
Make sure you check for proper push rod length.
Old Feb 4, 2014 | 04:44 PM
JakeFusion's Avatar
Super Hulk Smash
Johnson Short-Travel lifters or Morels.
Old Feb 4, 2014 | 05:47 PM
red fury's Avatar
Caddi race lifters
Old Feb 5, 2014 | 09:31 AM
TurboBuick6's Avatar
Originally Posted by red fury
Caddi race lifters
I would not trust those, do some research.
Old Feb 5, 2014 | 09:50 AM
PAC Racing Springs's Avatar
Closed ex-Sponsor Account
We offer a full lifter line for the LS engine. I would look at the PAc-LFT105-LS.
Old Feb 5, 2014 | 10:26 AM
intenseblue's Avatar
BTRs will probably go in my next build. Never heard/seen PACs lifters but theyre spring quality is top notch and you can bet there lifters will be great quality also.
Morels reputation has been outstanding over the years and if you ask the majority of in the know people that are in the lsx community youll probably hear that name first when you put the words best and lifters in the same sentence.
Not taking anything away from Brian Tooley or PAC. Theyre lifters have just not been around long enough for it to be sunk in everyones minds theyre #1 yet. Refer to my first sentence in this post.... and I consider PAC springs to be the best, not having tried BTRs yet. So all three would probably be great choices. Id stay away from GM lifters altogether...
With that being said, I had a chance to visit Vengeance Racing in September '13 and had actually asked Ron about BTRs as I was getting rid of LS7s. He said he hadnt used/seen them in action yet, but that in most of his street builds he used Morel 5290s. Even LS7 engines which turn 7000rpm stock. Things change over time and sponsors swap preferred vendors over time for too many possible reasons to be able to write down. If it were me Id call them and ask their opinion and probably BTR also. Both Ron and Brian are great to talk to. Good luck and if you can spend extra 100-200 greens then forget ls7s
Old Feb 5, 2014 | 10:47 AM
ATK Engines's Avatar
Morel = Lunati, the private label most of the line.
Stick with a GOOD Morel or the LS7 lifter, not the Street series.
Old Feb 6, 2014 | 01:38 AM
Burken01's Avatar
Originally Posted by jim1450
I'll bet you don't make them though!
My paycheck comes from GM & surely wouldn't use an LS7 or Caddy lifter, anyone that would tell you to use them is a fool.
Right now I have 3 sets of Morels, I need 1 more set of lifters & I will probably get another set, don't but the cheap Morels.
I personally wouldn't use the BTRs but everything I've seen so far says they're good so its hard to argue against them & especially for the price.
So your calling more than half the vendors on this site a fool? Texas speed, Brian tooley, fools?
No wrong, most lifter failures are actually not the lifter themselves. It's a wild valvetrain that was put together by a novice Inexperienced hot rodder that probably did no research or "followed" someone else's build without measuring PR length, preload, wipe pattern, improper torque sequence, etc...
Old Feb 6, 2014 | 07:24 AM
JakeFusion's Avatar
Super Hulk Smash
I wouldn't touch LS7 lifters either. But a crazy valvetrain will bust any lifter.
Old Feb 6, 2014 | 08:30 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
There's been failures from every lifter, and Brian actually said he's seen more Morel failures, and not many LS7's.
I ran LS7 lifters and never had an issue. Then again I measured and shimmed everything I need to, which goes back to the novice statement made earlier.
I'd NEVER order PR's with a cam at the same time. You've got to measure.
Old Feb 6, 2014 | 08:41 AM
Talk to some engine builders about the caddy race lifters, anyone who knows anything will tell you not to use them. Jim1450 is correct 100%. I wouldn't use them if they were free.
Old Feb 6, 2014 | 08:46 AM
JakeFusion's Avatar
Super Hulk Smash
One thing you have to do with any lifter is inspect it thoroughly and clean it. A lot of Morel failures are from trash or grit killing it. They have closer tolerances and don't hold up as well as an OE lifter to such things.
I spent quite a long time inspecting, cleaning, and testing the axles and link bars on all my lifters before install. I also put assembly lube on the body, the axle, and in the cup where the pushrod meets to avoid friction related damage on first start up.
Old Feb 6, 2014 | 09:28 AM
Burken01's Avatar
Oh I know the caddy lifters have a bad rap, I'm not backing them up lol
Old Feb 6, 2014 | 09:30 AM
Burken01's Avatar
If the shoe fits, they're in business to make money.
I think Brian would recommend his own before LS7s.
False again, Brian had recommended ls7's over his SLR lifters before.
It's all in the combo
