My build 396 cid on E85 w/ 14:1
Old 07-09-2014, 07:04 PM
  #321
98TransAmWs-6's Avatar
Got my lightly used FTP 104 lid from another member here.
I am also thinking about a flex plate and was considering a steel one by PRW since it is a really good price and looks like a quality piece and is SFI certified. Thoughts?
Old 07-18-2014, 11:28 AM
  #322
For head gaskets what size would you guys suggest for the 4.03 cylinder bore? I was thinking 4.085 but would that be too big?
Old 07-19-2014, 03:46 PM
  #323
Rise of the Phoenix's Avatar
I think those would work, but can you go smaller?
Old 07-20-2014, 07:10 AM
  #324
I haven't been able to find MLS gaskets smaller in the .040" thickness.
Old 07-20-2014, 10:23 AM
  #325
poltergeist 02's Avatar
I run a PRW flexplate, it looks to be the same as the Hughes brand. I'm happy with it so far.
Old 07-20-2014, 11:36 PM
  #326
Awesome good to know.
Old 07-23-2014, 10:16 AM
  #327
Sales@Tick's Avatar
IMO a 4.085" bore gasket is fine.
Old 07-23-2014, 11:36 AM
  #328
Awesome thanks Martin. I'll be buying that from you guys soon then.
Old 08-14-2014, 07:29 PM
  #329
Got my rear tires mounted today.
Old 08-15-2014, 07:50 AM
  #330
herecomesboost's Avatar
Awesome build. Those tires are wide!
Old 08-15-2014, 09:16 AM
  #331
Thanks! They are 335s! I dropped off the fronts to be mounted this morning as well.
Old 08-15-2014, 09:53 AM
  #332
I loved my 325's I had on my old CCW's. 335's even better, and if you could get them to fit, 345's for the win.
Old 08-15-2014, 10:04 AM
  #333
I would have went with 345s but I got the two used for $100 cheaper than one new tire and they are like new from a buddy. I couldn't pass the deal up.
Old 08-18-2014, 07:25 PM
  #334
Well I got my block loaded up and taken to the machine shop near me to ensure everything was up to spec prior to taking it to Tick Performance.
It was of course, in fact they said the machine work was outstanding. This was a block from Summit.
I also Test fitted the 335s. This was without any clearancing. They fit but it is extremely close. I am going to beat the fenders in to give for some additional room. Also yes I know I need to clean my garage.
Old 08-21-2014, 09:48 AM
  #335
99Z28camaro's Avatar
Awesome build man.. Staying tuned for results. I'm in the middle of building about the same thing 14.1:1 408cid. Keep us updated!
Old 08-21-2014, 10:03 AM
  #336
Nice to see an update. I'm glad your block checked out good. It seems it's been kind of hit and miss with the Summit blocks. Glad yours was good.
Old 08-21-2014, 12:13 PM
  #337
Hoping to drop it off this weekend! So excited.
Awesome if you have any questions feel free to ask me.
Old 09-15-2014, 06:45 PM
  #338
I have been looking at this stainless steel 14 gallon fuel tank that retains the stock sensors bolts up in the stock location and fills using the stock fill neck. I was wondering if anyone has used one and if it would be worth it for my build?
Old 09-16-2014, 11:09 AM
  #339
Sales@Tick's Avatar
I would keep the stock tank and go with a Squash in tank dual fuel pump set-up.
Twin Walboro 267's(compatible with ethanol) and move 450 lph a piece. Plenty of fuel for corn.
If you planned on spraying nitrous you could probably wire one of the pumps to run all the time. Then have the second pump wired up to your nitrous arming toggle switch where it only ran when you needed it on nitrous. That way both pumps aren't running all the time and possibly heating up your fuel causing vapor lock.
Or you could wire up the second pump to a WOT switch that activated your nitrous and that way the second pump would only come on when the nitrous came on. Instead of coming on via the toggle switch before the nitrous actually started to spray, it would only come on when the nitrous was actually spraying.
Old 09-16-2014, 11:22 AM
  #340
Alright I won't waste my money on that then. I do not plan on running nitrous I have a single walbro 450 (or 267 as you called it I have heard it both ways)right now. I was led to believe that would be enough for my set up. Would that not be? Also is the squash dual pump for 98s too? Since it seems a lot of the pump setups are different for the 98s.
Quick Reply: My build 396 cid on E85 w/ 14:1
