What is causing this GTO to run slower?
Check fuel pressure, coils could be weak and take valve covers off and check rockers and springs. DO you have any tuning software?
04 GTO IBM A4. 1 of 273. 1 7/8 pacesetter long tubes. Pacesetter 3" catless mids. SLP LM2 catback. Vigilante 4500. B&M supercooler. IPS motorsports Dyno tuned @352/350
Funny you mentioned tuning. Just asked on the tuning forum if there is a way to de-tune or restore to factory settings on the Tech2. No one has replied yet. Reason i ask is cz im starting to think the first owner might have tuned the car. The 2nd owner then replaced the motor. And now the 3rd owner has a car that is tuned for another engine. Love to know if there is that option on the Tech 2.
I told you why i don't think its due to the throttle not opening fully. If my reasoning is flawed...then plz do EXPLAIN why you think so...instead of just saying the same thing repeatedly.
You can still achieve redline with a throttle that is say, 75% open.
You'll need a scanner to verify the TPS is at 100%.
It sounds like the car needs to have a log of a couple of runs to see how things are acting.
Good Luck.
WHy do I waste my time posting............
I think he keeps asking if the PCM recognizes that the throttle blade is opening fully, ie, verifying that the TPS is at 100% when the throttle pedal is to the floor and then to verify that the blade is actually open at 100%.
Good Luck.
I will definitely get that checked.
I have hptuners and you can just about monitor everything to find the problem.
