What is causing this GTO to run slower?
Old Feb 12, 2014 | 12:31 PM
  #41
Freefallin's Avatar
Originally Posted by gagliano7
I don't know anything about the tech 2 but can you monitor everything with it?( I would sure hope so) I am sure the tech 2 can reset your tune since some people have went to the dealer with a tune and the dealer upgraded the pcm and they lost there tune.
I have hptuners and you can just about monitor everything to find the problem.
So im guessing an upgrade would reset everything to stock...
Old Feb 12, 2014 | 09:12 PM
  #42
tryintogofast's Avatar
You really need to find someone who has a scan tool and can use it to figure this out. There's a ton of possibilities that can the loss of power. Grab a scan tool.
Look at
Fuel Trims short and long-shouldn't be any more than +/- 10
MAP vacuum reading
MAF grams reading at idle
Knock sensors pulling timing?
ECT and IAT temps
A/F sensor
Or take it to a shop have a good diagnostic tech look it over for an hour and have them report back with what they find and tackle the job of fixing it yourself. I'll cost you anywhere from 80-120.
Old Feb 13, 2014 | 04:41 AM
  #43
Freefallin's Avatar
Look at
MAP vacuum reading
ECT and IAT temps
A/F sensor
Yeah good advice buddy!
What if there are no faults that show up on the scan tool. Am i looking for CEL or going thru everything even thou there is no code?
Old Feb 13, 2014 | 06:20 PM
  #44
Look at the values. Introduce vacuum leaks(lean it out) and carb spray(fatten it up) and make sure fuel trims are adjusting correctly.
Old Feb 16, 2014 | 03:15 PM
  #45
Freefallin's Avatar
Alright folks! Bringing this back up with an update.
Yesterday we took the injectors out just to clean them and, lo and behold, one injector wasn't flowing like its siblings! Replaced it and now a whole second has been shaved off the 0-60 time.
When you first step on it the car sounds like it is missing until it gets up in rpms......
Good catch gagliano!
As happy as i am to find the culprit, fact is, car is still slow. 7.4 secs to 62mph is embarrassing for an LS1.
Old Feb 17, 2014 | 08:04 AM
  #46
Z28Dave's Avatar
If the car is hesitating when you goose it then you might want to give the O2 sensors a clean or replaced. A faulty O2 will make a car miss fire and bog down like crazy until WOT. Also I wasn't sure if this was answered but is the SES light on at all maybe you should start from there and just get a simple code reading.
Old Feb 17, 2014 | 10:18 AM
  #47
ez2cdave's Avatar
I have a couple of "off the wall" theories . . .
(1) The Traction Control is not disengaging, even though the switch is in the "off" position.
(2) The Torque Converter is stuck in "lock-up mode".
(3) Did you change the Air Filter ?
Just some thoughts . . .
Old Feb 17, 2014 | 01:42 PM
  #48
RockinWs6's Avatar
Maybe you should release the parking brake.............................
 Michael S. Palmer
Old Feb 17, 2014 | 08:05 PM
  #49
jesselee128's Avatar
Hahahahhaa. I love your come backs! lol
Old Feb 17, 2014 | 09:25 PM
  #50
JD_AMG's Avatar
http://www.youtube.com/watch?v=wk6AgS-ShhU
http://www.youtube.com/watch?v=y5L5yF82-yI
Im not sure how you are measuring your times, and im not trying to be nit picky, but if you are judging off those videos theres a good reason its slow, you need to brake torque it... Don't just hammer it off idle, brake torque it then let go of the brake.
For example:
Old Feb 17, 2014 | 11:23 PM
  #51
Z28Dave's Avatar
Is this a chevy lumina SS? i just noticed the overlay on the speedo. if so it would also help if you state if its a 4 door, ute or coupe being as they have a weight difference. but i'm going to guess that they both are coupes by how to referred to them as gtos. or is it a goat with a lumina ss overlay?
