lq9
Old Feb 10, 2014 | 03:03 PM
my406cid's Avatar
Default lq9
Anyone build a stock stroke lq9/ls3 with a 4.125 bore with ls3 heads for the street? I know the bore will u should the valves but will it be a spinner or torquy? I know cam plays the role but just askin
Old Feb 10, 2014 | 05:12 PM
96capricemgr's Avatar
Really 4.125 BORE in an LQ9 block? Sleeves?
See you are in WI who is doing the machining?
Old Feb 10, 2014 | 05:15 PM
Werewolf SS's Avatar
It can be done but you have to get special made pistons. Even then it's not recommended to be daily driven like that. 4.125 is just to long a stroke on an lq block. The piston skirt sticks out the bottom of the bore and causes issues.
Old Feb 10, 2014 | 05:33 PM
Reread his post he specifies stock stroke 4.125 bore.
Old Feb 10, 2014 | 05:38 PM
My bad saw the second post first. Well first off you can't take an LQ to 4.125 bore. 4.06 is what most say is the furthest before it becomes an issue of integrity and a wall thickness test would be recommended.
Old Feb 11, 2014 | 07:36 PM
my406cid's Avatar
Y can't sleeve or use ls3 block? This is a paper build at the moment.is it doable? I don't know who would build yet but just wondering how she may act and would u need special pistons?
Old Feb 11, 2014 | 07:49 PM
garygnu's Avatar
what the engine characteristics depend some what on what cam you use .I would not bore out a block much past its cast bore ,unless you sonic check it .ether use a bigger bore block ,or use a 4" crank with a .030 over bore .check Texas Speed to see what pistons they sell with that bore ,and see what rod and crank it works with .do a search here or check U-tube .
Old Feb 11, 2014 | 08:04 PM
my406cid's Avatar
Sorry shouldn't of said a lq9. A re-sleeved ls3 block.
Old Feb 11, 2014 | 08:15 PM
my406cid's Avatar
I was thinking of a ls3 version of a 377 with a big bore shorter stroke. I think the cubes end up at 388. Fig with a bore and stroke like this it would make a cyl head shine with the valve shrouded less. Alot of heads are flowed at 4.125 bore
Old Mar 31, 2014 | 11:02 AM
my406cid's Avatar
Bump to top
