Cam only LS1 Spark Plug Gap???
Hey what's up guys. I have a cammed ls1 with longtubes and a cold air intake...i have the ngk tr55s at .55 but people say they have there's at .35 what gap should i use? Thanks!
.55 is a little much I'm almost certain you should gap at .40 .35 is for stock application and will work for mild cams. Talk to Pat G. He's great at anything you throw at him. Patrick@guerragroup.com
I would agree with this...I had a bad back fire after changing plugs and wires (MSD red wires)...turns out the insulator on 3 was just touching the header, it would backfire under light load etc, caused flashing CEL...I would look it over again, maybe run a scanner, it should have a trouble code with a backfire/misfire.
Yes I'm sure, i gapped them back to .55 and it runs good, but had to send computer back cause tuning problems
...but when i get it back I'll gap em at.40 and double check everything
