94 silverado Lq9 performace upgrades
I'm planning on using long tube headers ground clearance Is a concern as of now it's a static drop 4-6 considering bagging it at a later time
( any brand preference suggestions?)
No cats, single 3 or 3&1/2 exhaust or would dual be better
I'm looking for some upgrade ideas such as which cam would be a good balance between power, daily drivability and price
I have a throttle cable intake I'll be using and have a BBK 80 mm tb I can use
I'll be using a 4l60 with 3.42s in the diff
Also stall recommendations?
I'd like to see at least 350 hp when I'm done
Thanks
It was a motor I pulled from customers car (an 05 escalade )that was running hot
They supplied me the motor and chose a 5.3 from a salvage yard because they were trying to get out as cheap as possible
Had about 65000 on the odometer
so I pulled them to have em checked
So I gotta get gaskets and bolts anyhow and was just curious if it would even be worth my while
What size tires? If up in the 30" tall range I would seriously consider 3.73s.
For your extremely mild goal no porting is necessary.
And as far as tire size I have 295-40-20 rear that stand at around 28.5 tall
Been looking around for a set of 3.73s anyways
Im still not locked in on cam choice and now with all the input I'm considering trying to make more power than what I'd initially decided to shoot for
28.5" I would still consider 3.73s for a street truck that will still see some highway, 4.10s really aren't bad OD and lockup and such really tames it. 4.10s with a 4L60E is similar to 3.08s with old school 3 speed tranny with 1:1 ratio.
