Difference in GM LS7 Lifters
Old Feb 23, 2014 | 04:24 PM
rich's Avatar
Default Difference in GM LS7 Lifters
Looking at lifters. does anyone know the difference between the LS7 12499225 and the GM performance 88958689 lifters?
Old Feb 23, 2014 | 04:28 PM
high impact's Avatar
If those are the ones I am thinking of they are the same. Individual versus a set for part numbers
Old Feb 23, 2014 | 04:38 PM
rich's Avatar
on Ebay there are both listed and come up under a LS7 search. the LS7 set of 16 are about 160 bucks the performance ones are 300 bucks.
Old Feb 23, 2014 | 04:51 PM
You should be able to get them cheaper then that at your local Chevrolet dealer, I know I can. I think texas speed is 139 if I am not mistaken. When you order them though be sure to order a full set and pay as a full set. I was told at my Chevy dealer that they are the same lifter but priced either individually or as a set. Same lifters - but I quit buying parts off eBay.
Old Feb 23, 2014 | 05:22 PM
CattleAc's Avatar
GM parts direct has them listed as separate part#'s of 16 lifters each...
I don't think they are the same lifters.
Old Feb 23, 2014 | 06:24 PM
rich's Avatar
I was just doing a search and found the 2 different parts numbers. The gm performance part set for 299 is from Summit Racing. Not going to buy them from ebay just checking pricing.
Old Feb 23, 2014 | 07:07 PM
DietCoke's Avatar
GMP have ceramic check ***** and less internal travel. They're the cadillac race lifters.
Old Feb 24, 2014 | 12:47 AM
COSPEED2's Avatar
LS1Tech Sponsor
17122490. That is the pn for a single GM lifter which is used in all LS engines now (save for the 8 different ones used in the AFM engines). It is the single pn for the "ls7 lifter set". The 8689 pn in question are the "Caddy Race" lifter set.
Old Feb 24, 2014 | 01:49 AM
COSPEED2's Avatar
LS1Tech Sponsor
And yes, we can match the price from SD on the ls7 lifters. They have been working very well since...well really 2005 right? There is no doubt there are better lifters out there, but for mild cam lobes they work very well and for high mileage vehicles they are a no brainer. Most of the used cams out there you will find barely have lift over .600 and the lobes are nowhere near the LSL and up type of ramp rate, so they work pretty good. Most people use them for everything and get by. We sure do not recommend that, but it is being done.
Old Feb 27, 2014 | 01:10 PM
COSPEED's Avatar
http://www.coloradospeed.com/comp-ca...-ls-p-263.html
are no slouch either.
Old Feb 27, 2014 | 01:17 PM
TurboBuick6's Avatar
Originally Posted by DietCoke
GMP have ceramic check *****, They're the cadillac race lifters.
Fixed.
Old Feb 27, 2014 | 02:26 PM
COSPEED2's Avatar
LS1Tech Sponsor
We do have other lifters as well. The lunati drop ins and the Lunati tie bars are very well priced and very good quality.
Old Mar 11, 2014 | 10:36 PM
COSPEED's Avatar
Here they are, just under a different part number. We've got these at an introductory price and then BAM, it goes up.
http://www.coloradospeed.com/delphi-...s-p-32274.html
Here are the Morel drop ins at an introductory price and then BAM, it goes up.
http://www.coloradospeed.com/morel-h...3-p-32269.html
Old Mar 11, 2014 | 11:01 PM
I like the sound of those Morel drop ins! I was about ready to buy a set of ls7 from my local dealer but may grab these Morel lifters while you are offering a special. How much better would you rate the Morel over the ls7 lifter for a xer lobes G5x3 cam?
Old Mar 11, 2014 | 11:05 PM
Dang, I just noticed those Morel drop in lifters aren't for LS engines...wrong link?
Old Mar 12, 2014 | 12:06 AM
COSPEED's Avatar
Link is correct.
The Morel is conservatively good for 7Kish while the LS7 is around 6Kish.
Old Mar 12, 2014 | 09:30 PM
LilJayV10's Avatar
The Morel's drop in's definitely have my interest. I had not heard of these.
Old Mar 12, 2014 | 09:31 PM
COSPEED2's Avatar
LS1Tech Sponsor
They are a very good option, and most people do not know about them. They are still a "street" version with the captured roller, but a better option to the LS7 indeed.
Old Mar 12, 2014 | 09:35 PM
COSPEED2's Avatar
LS1Tech Sponsor
For those that may not know, the LS lifter is exactly the same as what is used in the LT1s and Vortec engines.
