how much to forge my bottom end
Old May 12, 2004 | 06:18 PM
2001zz's Avatar
Default how much to forge my bottom end
I am looking in buidling my bottom end forged. What is a budget price? is there a kit available. and I do not want to buy a shortblock already assembled, I am not paying someone else to build a motor for me. I just need materials and around about how much the cost will be. I understand that the stock cranks are very strong and i wont need to change it
Old May 12, 2004 | 06:31 PM
Pacific Muscle Cars's Avatar
Even for a budget forged build, plan to spend $2500 or more just on the shortblock. Here is what I have wrapped up in mine:
Pistons/rings $650
Rods $500
Bearings $150
Gaskets $200
Machine Work $650
ARP Hardware $350
Timing Set $75
Oil Pump $150
That's $2,725 - not including the other things you will likely want to do at the same time.
Old May 12, 2004 | 06:35 PM
2001zz's Avatar
why the 650 on machinework? Is there anywhere that has a kit already together?
Old May 12, 2004 | 06:50 PM
ITSovr4U's Avatar
I couldnt tell you, But i know someone who can....Call Chris or Brian at APE..I guaranty they will do you right.
Old May 12, 2004 | 06:58 PM
Machine work is the most critical aspect of the build. The block should be cleaned, bored/honed, align honed, zero decked, cam bearings installed, crankshaft polished, and the rotating assembly should be balanced.
Old May 12, 2004 | 07:35 PM
2001zz's Avatar
i know all about machine work. but my question is for example on a ford engine or non ls1 chevy block you can have machine work done for much less. balancing included. is there something special about the ls1 blocks?
Old May 12, 2004 | 08:07 PM
JZ'sTA's Avatar
Welcome to the LS1 world where everything is nicer but costs much more.
Call APE as said before they will hook you up nicely.
Old May 12, 2004 | 08:15 PM
2001zz's Avatar
im not ready to buy yet just exploring my options. I wish someone had a kit made up already. I would call ape but dont they just sell assembled shortblocks. I am not paying anyone to build this motor, this will be built by me i just need the materials.
Old May 12, 2004 | 08:46 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Give us a call, we do also just sell the parts. Anyway you want them.
Thanks
