click/tick....diagnose??? help??
Old May 12, 2004 | 07:43 PM
soundengineer's Avatar
Default click/tick....diagnose??? help??
can anybody tell me what this is...
definately louder from underneath the car....
http://www.audiohelix.com/mofbody/click.mp3
has been hapening since I swapped heads... wondering if maybe its an exhaust leak??? from the headers??? maybe at the collector...cant really see anything obvious...
but its real annoying
Old May 12, 2004 | 10:31 PM
jd13's Avatar
Couldn't tell from the sound clip, but did the ticking increase when the rpms increase?
Leaks are never really obvious. Take out all the header bolts and retorque them in the proper order. Do you have block off plates for EGR or AIR? Check those. If it is at the collector, than I'm not sure cause I don't know how you have it hooked up.
Another thing is that my car developed a ticking sound like that but not as loud 3 days ago. It took me until today to figure out it was a loose spark plug wire. It somehow worked it's way a little loose. Since you have had the heads off, I know you've had the plugs/wires off as well. Recheck all those connections.
Good luck!
