Thoughts on this engine noise?
Old Feb 28, 2014 | 05:41 PM
MysticTealTA's Avatar
Default Thoughts on this engine noise?
Hey all.
I've had a couple people listen to this video and I know it's too hard too tell anything definitive through a video clip, but just wanted to get more thoughts so I could mentally prepare for what might be in store.
Quick run down: all stock internals, just a bolt-ons car that's been daily driven and has a lot of 1/4 mile time as well, 110k miles. Two days before it sounded to me like the typical cold weather piston slap was a bit worse, but it would go away, but the car had a slight hesitation from a dead stop. Then I started it one evening and it made this lovely noise. Good oil pressure. This actually happened in early December so it's been replaced as a daily driver, but now I want to get it running again and make it a little more fun. Thoughts?
I will try to at least get the valve covers off in the near future. Being a single girl with a broken motor and shallow pockets is not a good combination! haha.
Old Feb 28, 2014 | 05:54 PM
Russ K's Avatar
Check for a broken flywheel, or loose bolts.
Russ Kemp
Old Feb 28, 2014 | 05:57 PM
Lockdown99ss's Avatar
Russ Kemp
I had this exact same sound and it turned out to be a loose flywheel bolt.
Old Apr 18, 2014 | 02:50 PM
Just an update. The outcome was a bent rod and the crank hitting the piston skirt. There goes another one to hydrolock. Cylinder 6 too like so many others on here.
Old Apr 18, 2014 | 06:28 PM
ls6jay's Avatar
Default bent
What head gaskets?
Old Apr 25, 2014 | 06:54 PM
They were stock head gaskets. Looks like it came in through the unbaffled nostrils of my hood.
