Help me with this loud Ticking Noise!
the motor has a 228r cam, TSP pushrods, and pac springs. i used 7.400 pushrods i did not check the pushrod length. could the wrong length pushrods cause this? anymore ideas? thank you!
This is what mine was doing. I Chased this problem for about 10 months. COuldent find it. CHange lifters a few different sets of pushrods. rebuilt the heads. You name it I did it. I was at the point of pulling the motor because I couldent find it and the engine just wouldent die either. I pulled the oil pump as a last resort. I had no signs of a oil pressure problem but their it was. A split oil pump oring. I replaced the pump and oring and haven't had a problem since.
also with the rockers torqued at 22ft-lbs I can move the rockers side to side and up and down a little. the trunions seem to have a little play, is that normal?
https://ls1tech.com/forums/16774455-post2.html
thanks for that link! I just went and tried it, I came up with ~1.5 turns, and he says he shoots for 1.25-1.75 turns. im right in the middle. so the push rods should be all set!
