trick flow heads?
Old Mar 13, 2014 | 11:49 AM
badassracing's Avatar
^^^ Thank you. I just feel bad for the guys that dont know any better.
Old Mar 13, 2014 | 11:51 AM
COSPEED2's Avatar
LS1Tech Sponsor
Originally Posted by Hamrdown
Lol come on man, don't pee on my leg and tell me it's raining. Any cam, there's a good bet they're leaving something on the table somewhere. One guy may have a t-Rex cam but he's leaving a lot of midrange on the table. It depends on the application. You pretty much called the 224 outdated crap! You knew exactly what you were doing. That sir is what I called you on.
You are hearing what I am not saying.I never called it crap. The lobes are dated and yes so is a single pattern cam. You didnt "call" me on anything. If someone else touted a similar cam from another company I would say the same.
Old Mar 13, 2014 | 12:03 PM
Baconz28's Avatar
I would give my guy a call for a custom grind cam. He just made 1400 horses our a procharger 5.3 using trickflow as cast heads. O that's brian tooley. Enough said
Old Mar 13, 2014 | 12:25 PM
68BBChevelle's Avatar
Ive got tea/tfs 220 heads with a Brian tooley cam. Will know what it lays down in a few weeks. Brian has done alot of R&D on trickflows so that's why I chose him to spec me a custom cam.
Old Mar 13, 2014 | 12:36 PM
KCS's Avatar
KCS
Moderator
Originally Posted by coSPEED2
Coming from the same guy that had non sponsor content in his Sig?
The HUC was designed off the extreme marine lobes. So please, tell me they are not aggressive.
What lobes are less aggressive than the HUC or Extreme Marine?
Old Mar 13, 2014 | 12:38 PM
Baconz28's Avatar
^^^ It's go be a killer. It's like if brian spec the cam. Your opponent *** is toast. What separates brian tooley from everybody else on his cams. He really understands heads and what each type of cylinder head likes. Plus he does heads in house.
Old Mar 13, 2014 | 03:37 PM
COSPEED's Avatar
Thumbs up
You seem to be on an anti TSP kick lately. I don't see them running down other shops or cams trying to drum up business. They can custom spec a cam just like you or any other shop with any of the Comp lobes. To the OP, as far as a cam, if you want a custom grind you have many options as far as vendors. Since you were already thinking about TSP's stuff you can call them and I'm sure they will walk you through it. Ask about a custom cam & give them all of your details. As far as heads, on a 5.3, I'd go with their stage 2.5 5.3 heads. Huge bang for the buck!
No, he's just giving his opinion and not all opinions are going to seem positive to everyone. We're a dealer for TSP/PRC cylinder heads, springs and exhausts and their products are great.
Old Mar 13, 2014 | 06:01 PM
No one knows more about trickflow heads then Brian read this below and give him a call.
http://www.briantooleyracing.com/about-us/
Old Mar 13, 2014 | 07:10 PM
AdReNaL!nE's Avatar
Originally Posted by 03EBZ06
I agree the typical posted lobe is not always the best now.
I had a shocker about 2 years ago. We put a 204/218-117 -2 in my car.
Produced 496/530 or somewhere near that. Engine in sig. All about the heads!!! And TFS are great heads!
this might be a stupid question, but when it comes to sensors what all does the 5.3 need to start? like the crank sensor obviously but what else? and is it worth doing a cam swap in a 5.3 that has 200,000 miles on it? and what cam would be best for a cam only Silverado
