trick flow heads?
Old Mar 6, 2014 | 05:11 PM
AdReNaL!nE's Avatar
Default trick flow heads?
im building a 5.3 and I was going to do ls6 stage 2.5 heads with the 224r cam, but I was searching and will be getting my motor tomorrow and cant decide if I should do that combo or the trick flow gen x kit with there heads and there 285/292 cam, cant decide, I want at least 450 at the crank N/A
Old Mar 6, 2014 | 07:24 PM
redtan's Avatar
If you have the money, get the trickflows as those will outmatch any ls6 head. But go with a custom cam from a vendor here not some off the shelf cam from them.
Old Mar 6, 2014 | 08:27 PM
COSPEED2's Avatar
LS1Tech Sponsor
A custom cam will net you the torque you will likely want with a low HP est. The trick flow as cast heads can get you there no problem, but there are so many better lobes out there that the older cams cannot match.
We can set you up if you are interested!
Thanks
coloradoSPEED
Old Mar 6, 2014 | 08:32 PM
Lowmiles's Avatar
Trickflow 205s would be your best bet with the 5.3 with a custom cam.
Old Mar 12, 2014 | 06:53 PM
AdReNaL!nE's Avatar
well I was looking at texas speeds 224r cam, I just don't know how well they would perform with the trick flow heads, that's my only problem, choosing the right cam for the heads im using, my goal is only about 370 at the wheels
Old Mar 12, 2014 | 06:58 PM
COSPEED2's Avatar
LS1Tech Sponsor
It wont (the 224r). We can get you a custom cam that will exceede those goals easily with good street manners.
Old Mar 12, 2014 | 07:04 PM
JakeFusion's Avatar
Super Hulk Smash
TFS 205s.. CNC ported, 58cc chambers, and designed for the 5.3L... $1999.
Then I'd go with an EPS 222/226 113. Would make a ton of power.
Old Mar 12, 2014 | 07:05 PM
COSPEED2's Avatar
LS1Tech Sponsor
There are better lobes than that that are also easier on the valvetrain....
Old Mar 12, 2014 | 07:11 PM
AdReNaL!nE's Avatar
Thanks
coloradoSPEED
that would be great! how do I contact you
Old Mar 12, 2014 | 08:22 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Easier than the 224r or the EPS cam? Geoff has some of the easiest lobes on the market.
Old Mar 12, 2014 | 08:56 PM
COSPEED2's Avatar
LS1Tech Sponsor
Nearly identical as a matter of fact...and some of them softer yes. And def better than a single pattern cam with XER lobes.
Old Mar 13, 2014 | 02:32 AM
Hamrdown's Avatar
You seem to be on an anti TSP kick lately. I don't see them running down other shops or cams trying to drum up business. They can custom spec a cam just like you or any other shop with any of the Comp lobes. To the OP, as far as a cam, if you want a custom grind you have many options as far as vendors. Since you were already thinking about TSP's stuff you can call them and I'm sure they will walk you through it. Ask about a custom cam & give them all of your details. As far as heads, on a 5.3, I'd go with their stage 2.5 5.3 heads. Huge bang for the buck!
Old Mar 13, 2014 | 06:17 AM
03EBZ06's Avatar
I agree the typical posted lobe is not always the best now.
I had a shocker about 2 years ago. We put a 204/218-117 -2 in my car.
Produced 496/530 or somewhere near that. Engine in sig. All about the heads!!! And TFS are great heads!
Old Mar 13, 2014 | 09:51 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
The 224R is a good, proven performer that has lasted the test of time. That's why it still remains one of the best selling cams out there. Give me a call and we can go over your application and goals with your set up. I'll point you in the right direction and we can discuss going with a custom specced cam. I've specced smaller cams with a lot more torque, same top end or better, and still have the same sound that the 224R makes in a 5.3.
Lonnie
Old Mar 13, 2014 | 10:20 AM
Rise of the Phoenix's Avatar
Ed Curtis also makes some very bad *** cams that would be great with your application. Streetsweeper HT, Streetsweeper TQ and Streetbeast TQ. He could also hook you up with a custom stick.
Old Mar 13, 2014 | 10:40 AM
badassracing's Avatar
Coming from the same guy that said (in another thread) HUC lobes are more aggressive than the standard aftermarket cam lobe.
Old Mar 13, 2014 | 11:15 AM
COSPEED2's Avatar
LS1Tech Sponsor
Coming from the same guy that had non sponsor content in his Sig?
The HUC was designed off the extreme marine lobes. So please, tell me they are not aggressive.
Old Mar 13, 2014 | 11:19 AM
COSPEED2's Avatar
LS1Tech Sponsor
Not anti TSP just letting the customers know that they could be leaving quite a bit on the table. Everyone wants the most bang for the buck, then they need to info to do so. I even promote parts we dont sell just so the customer has the best info and parts avail. Tech info is important also, not just making a buck.
Old Mar 13, 2014 | 11:29 AM
Hamrdown's Avatar
Lol come on man, don't pee on my leg and tell me it's raining. Any cam, there's a good bet they're leaving something on the table somewhere. One guy may have a t-Rex cam but he's leaving a lot of midrange on the table. It depends on the application. You pretty much called the 224 outdated crap! You knew exactly what you were doing. That sir is what I called you on.
Old Mar 13, 2014 | 11:34 AM
I'm not looking for a debate. Its just that EPS is known to have milder lobes than most. Its also known that Extreme Marine and HUC are not aggressive lobes compared to the standard aftermarket cam.
