853 to ported 241 lost power?
Of course, if the ported 241s are hogged out... then nothing is helping that.
Did you degree the cam? (Assuming no)
Who ported the heads?
Who knows how big the runners and the chambers are, or if they are even equal across the board. With those randomly hogged out by some guy with a dremel, I'm not surprised your results are all over the place. You could've lost significant air velocity and compression (even with the earlier ICL) which would explain the loss in low end power.
I blame the heads, fairly sure his are hogged out likely destroyed all velocity they had.
