will valve springs from 243 heads fit on a ls1??
ok I went to the track yesterday and my car hesitates real bad at high rpm, my valve spring are binding, I have a set of 243 heads in the garage.
WILL the springs from the 243 heads work on my stock ls1 heads with my stock cam??
I know it sound weird but im trying to see how fast I can go with stock heads/cam..
went 10.5 @ 128 yesterday
watch my run at the end of this, if you listen closely right when im passing the finish line you can hear it hesitating, its not the rev limiter we turned that up high
