looking for cam advice for ls1
Old Mar 12, 2014 | 10:08 AM
shitandgetz's Avatar
Default looking for cam advice for ls1
i have a 2000 camaro ls1. looking to do a cam. has stock 241 heads
Mods:
long tube headers
ls6 intake
3.73 gear
slp lid
has a stock converter but will change to match cam
this is not my daily driver.
Old Mar 12, 2014 | 01:37 PM
sixspdss's Avatar
Are you going to replace the valve Springs because that's a big deal when doing a cam swap with what ever lift you want to go with
Old Mar 12, 2014 | 01:54 PM
was trying not to with the stock 241 heads. if i am going to change spings think i should get a better head first. that is more then i can do right now. was hoping i could find a cam that would give me a little more power and choppier idle. with out doing anything to the heads just yet. is that not possible ?
Old Mar 12, 2014 | 02:21 PM
DANOZ28's Avatar
most would agree the valve springs are the weakspot of an ls1 engine. my stock springs started to float / bounce at 5800 rpm. (w stock cam 48k miles) i would not upgrade the cam w/o better springs. (ever)
Old Mar 12, 2014 | 02:45 PM
01ssreda4's Avatar
Even stock cams might benefit from a better spring. A spring and pushrod change is mandatory for an aftermarket cam. No two ways about it.
Old Mar 12, 2014 | 03:19 PM
99Bluz28's Avatar
As already stated, better valve springs are a must! If you're not willing to upgrade the springs then don't even bother with a cam upgrade.
Old Mar 12, 2014 | 04:00 PM
sixspdss's Avatar
Yeah if you get the dual valve springs with a .650 lift you could go with a really good cam like the torquer v2 or the polluter cam tick performance is what I would recommend if it's not daily drivin but either way whatever cam you go with I would definitely upgrade springs
Old Mar 12, 2014 | 07:58 PM
MMWS6's Avatar
Stock heads Id do the GM Hot Cam... I know guys here will say a big no, but with stock heads you are not going to get much going over a 220 intake. Then you need it biased to the exhaust with those heads. So again, the Hot Cam may be just what you want. 219/228 and the ramp rate is not going to have you changing springs all the time from breakage. If you then add a simple set of AI Ported heads for a grand or so you'll get good use of it. On top of that it would take a bit of boost quite nicely having the split it does should you go that route down the road.I think it will give you some room to grow and be useable from the start if you get the kit that comes with springs.. just my 2 cnts I have the Hot Cam Kit here and am installing as soon as we get some nice weather. I also plan on AI's ported 241's that they are now offering. A set of 1 3/4" long tubes with an ORY and a SLP back loudmouth. I think the combo is going to be just what I want out of the car
Old Mar 12, 2014 | 08:17 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Street Sweeper HT (or TQ) springs (Brian Tooley) and Push Rods.
Old Mar 12, 2014 | 08:34 PM
sokr915's Avatar
This. Ask me how I know
Old Mar 13, 2014 | 05:57 AM
thanks for all the ideals everyone. helping out a lot, keep them coming lol still haven't made a final decision.
Old Mar 13, 2014 | 06:56 AM
looking at this cam maybe? 54-600-11 comp cam part number. 219/233 .553int .536exh lsa109. what you guys think about this cam. then get some ls6 beehive springs they say they are good up to .570 lift.
or a ls6 spring they say they are good up to .560 lift or would that be cutting it to close to there max lift?
Old Mar 13, 2014 | 07:10 AM
redbird555's Avatar
In short, no i wouldnt.... Aftermarket cams have usually have very "aggressive" lobe ramp rates. I dont know which lobes this cam is ground on but it most certainly more aggressive than a stock cam. Could you get away with ls6 springs? Probably. However I can see them not living a long life or a happy one with the good chance of valve float. If you went with a mild cam a set of pac 1218's would be fine... Good to 600 lift and are just over 125 bucks
Old Mar 15, 2014 | 08:18 PM
Anyone ever run this cam. 228/228 .588/.588 112 lsa or what you think.?. i will be getting the springs that are needed for this cam also
Old Mar 16, 2014 | 07:17 AM
01ssreda4's Avatar
You need Comp 918s or PAC 1218s at MINIMUM with an aftermarket cam.
