Oil pressure wont rise.. bypass problem?
recently fixed a low oil pressure problem but now i have encountered a new problem. oil pressure will not increase with RPM AT ALL!
45psi cold idle
30psi hot idle
melling 10296 pump (used)
could the bypass be stuck causing the oil pressure not to rise with rpm? bearing clearances are fine i just checked them last week.
10-30 non synthetic oil. (trying to break in a new engine) stock rotating assembly.
not an oring problem ive changed it 3 times now (blue, black, blue) all the same results.
45psi cold idle
30psi hot idle
45psi cold idle
30psi hot idle
45psi cold idle
30psi hot idle
