Need help Identifing cam lobes for a comp cam
BUmp come on cam gurus some one identify these lobes for me I want to see if this cam will work with my ls3 heads with out the hollow stem intake valves. Im worried the lobes are to aggresive for the heavy intake valves.
what lobes does the cam have Im trying to find out if they are to aggressive for my heavy stainless intake valves in my ls3 heads. I know the cam works well with stock ls3 heads on a stock ls3 not sure with these heavier stainless valves I have.
The stainless valves in an ls3 head are not heavy. Maybe a big block. Those lobes will work but we can spec you a better cam that is made for what you want. I have talked to you about this before.
