GM performance LS stage 1,2 cams.
Old Mar 15, 2014 | 12:43 PM
01WS6/tamu's Avatar
Default GM performance LS stage 1,2 cams.
I was looking at the gm performance 2014 catalog online in the LS section there are 2 cams toward the bottom listed as stage 1,2 and gives specs on the cams. There are no further descriptions as to their intended usage or engine CID they are designed for. Anyone know much about these cams by chance.
Old Mar 15, 2014 | 02:00 PM
redtan's Avatar
Why don't you give us the specs of those cams and we can tell you what they would be good in.
Old Mar 15, 2014 | 06:58 PM
01WS6/tamu's Avatar
PN 88958772 LS stage 2 cam
intake 227 exhaust 239, max lift 1.7 rocker .551intake and exhaust, 108 lobe separation, maxlift 1.8 rockers .583
PN 88958773 LS stage 3 cam
intake 233 exhaust 276, max lift 1.7 rocker .595 intake and exhaust, 107 lobe separation, max lift 1.8 rockers .630 intake and exhaust
Straight from 2014 performance parts book.
Old May 23, 2014 | 08:54 PM
tk-mpl's Avatar
I am curious on this as well. I am building a 2010 6.2L VVT and would like to know... Anything comparable to a Texas speed or comp cam??
Old May 23, 2014 | 09:03 PM
HCI2000SS's Avatar
Low to moderate lift with a tight LSA...sounds a little different than the normal LS cams out there
Old May 26, 2014 | 09:41 AM
JustAFooL's Avatar
Much different cams than most. I would be curious to hear one of these things, I thought the trex cam sounded nasty when it came out and it was a 110.. Can you imagine a 107??
Old May 27, 2014 | 01:00 PM
SSCamaro99_3's Avatar
Probably designed for a carburated setup. You usually do not find LSA'a that low when using a production style manifold, but I am far from an expert on these matters.
Old Feb 8, 2017 | 06:41 PM
Jesse Williams's Avatar
I am running a gmpp stage 2 camshaft In an ls3. It is very surge below 2k. It has a dragster style idle "baby copo" from 3k up it is serious! Peak tq @4600 peak hp @6600. 34°-37° total timing above 3k.
Old Feb 8, 2017 | 06:54 PM
They are all out motor cams. NO NITROUS, NO SUPERCHARGER. They put out serious power in the mid to top end range. Stage 2 is street able with 4.10 gears. Needs 2k and above rpms or it becomes unhappy.
