Rings and gap for nitrous/boost wiseco piston
My first question, what are the best rings to use for nitrous and boost with these pistons? I plan to hit it with a 200-300 shot for a couple years then swap out heads and boost it later. I am reading a lot on here about total seal and wiseco gfx rings. It appears I need a steel top ring.
My second question is, what are the best ring gaps for my intended use? I am finding some conflicting information. My machinist is telling me to gap top .022 and second .016 but I am seeing on the boards recommendations top .019 and second .021. There seems to be quite a contrast between recommendations.
One last thing, how do I figure out static compression ratio? My pistons mock up .003-.004 under the deck and the machinist took .010 off my 241 heads. Is there a formula I can use to determine compression ratio and how much can we safely mill these heads?
Thanks!!!
Thanks!!!
In your situation I'm guessing with 3cc valve reliefs and GM gaskets you're probably only at 9.8:1 but a .040" Cometic could get that up to 10.2ish.
I'd run the Speed Pro Hell Fire ring set for the spray now and boost later.
You'll definitely want to run more gap on the secondary ring to reduce inter-ring pressure which causes flutter and unseats the primary ring tension sooner in the power stroke. This is one reason why dry sump engines and wet sump drag engines with air pumps benefit so much from reducing crankcase pressure which promotes better ring-seal.
If you are serious about spraying a 300 shot then I'd put the primary gap at .024" and the secondary at .026". You'll sacrifice just a few ponies on NA with them on the loose side but you'll wreck a bunch of **** if they're on the tight side.
I thought the ring gaps didn't sound correct. My machinist is very well known around here for many years of reliable engine building and fantastic work but he obviously doesn't have the LS engine experience he claims. He has too many old school engines in the winners to even count so I know his work is top notch.
the compression 10.19. Your pistons have 3CC and are now down .010" from stock and
although you've milled your heads .010" the combustion chamber shape is still less than
the bore diameter so yoy lost comp.
That's what I will do if the compression will work with my G5x3 cam now. I do plan to swap cam, heads and intake when I boost in a few years.
I also found the ring gap chart from wiseco and they show .005 for top ring x bore size and .0055 for second ring. That puts me at .019 and .021. I think I will run the bigger gaps like you recommend - it seems larger gaps aren't hurting anyone but too small a gap kills engines.
Does this seem like a solid approach? Thanks for dealing with my rookie questions!!!
What kind of budget are you working with for heads ?
The 706 heads have a 61cc combustion chamber as they sit. If your $$$ allows you get get them P/P and bigger valves to help them flow a bit better.
I get 10.8:1 compression with the 61cc heads, .040 / 3.910 cometic gaskets. That with a 200+ shot will be enough to get in trouble.
Thanks!!!
...................................Fuel........... .....Top Ring.............Second Ring
Nitrous 150HP-350HP....Gas, Alky, E85....Bore X .0065"........Bore x .0065"
Oil Ring
Min .015"
Which is .025 top and .025 second.
I have found cometic produces a 3.910 stainless steel head gasket in .027 compressed thickness. That gains me another .013 with no more milling. But will that gasket cause any sealing issues? My machinist is going to cc the heads to see exactly where we are at since the multi-angle valve job pushed the valves into the combustion chamber decreasing the chamber volume.
If I am figuring correctly; 3.905 bore, 3.622 stroke, 64.5 combustion chamber, 3.0 valve relief, 3.910 bore .027 thick gasket at .003 piston deck height should put me right at 10.69 to 1. That would work if it is correct.
Almost there!
