solid roller cam comp cam 54-500-11 with hydo lifters?
Hyd lifter 233/360. So these two lobes one with Hyd one with solid with .008 lash. They will have the same valve motion but different looking specs.
What's the typical "re-adjust interval" for solid roller lifters ?
Problematic on an LS motor in a 4th Gen F-Body, due to the motor being set back under the cowl ?
- IO @ 18.0 BTDC
- IC @ 35.0 ABDC
- ICL @ 98.5 ATDC
- EO @ 63.0 BBDC
- EC @ 2.0 ATDC
- ECL @ 59.5 ABDC
- Int duration @ 0.050" = 233°
- Exh duration @ 0.050" = 245°
- Int lift = 0.600"
- Exh lift = 0.609"
- LSA - 109.5°
- IO @ 18.0 BTDC
- IC @ 35.0 ABDC
- ICL @ 98.5 ATDC
- EO @ 63.0 BBDC
- EC @ 2.0 ATDC
- ECL @ 59.5 ABDC
- Int lift = 0.600"
- Exh lift = 0.609"
- LSA - 109.5°
This will be a long one I will PM you.
