Help with pushrod measurements
Old Mar 23, 2014 | 07:55 PM
02fbody35th's Avatar
Default Help with pushrod measurements
Hey guys I'm in the middle of installing a set of AI 243 heads they were milled .030. I'm also installing LS7 lifters and the car already has a gm hot cam. I just need a confirmation in my pushrod measurements. With the comp cams tool I measure out 8.5 turns 8.5x.050=.425+6.8=7.225 if I add in .075 for preload I get a 7.300 pushrod. Smallest off the shelf I found was 7.325 which would give me .100 preload. Is this to much? Now to check my measurements I used the counting of turns to reach 22ftlbs. With my tool set at 7.325 length, from zero lash to 22ftlbs I came up with 1 3/4 turns which is what's recommended. So is 7.325 where I want to be?
Old Mar 23, 2014 | 08:43 PM
Darkman's Avatar
Your calculations look correct. I don't run those lifters so I cannot speak to that preload level other than to say others on this board run that much.
Old Mar 24, 2014 | 04:58 AM
vettenuts's Avatar
Trand pushrods will have them in stock and make the pushrods for most other companies including Comp.
Old Mar 24, 2014 | 05:31 AM
redtan's Avatar
http://www.briantooleyracing.com/pushrods/
BTR has pushrods less than 7.300
Old Mar 24, 2014 | 06:01 AM
mcdonald77's Avatar
I have comp 7.3's with less then 20,000 miles $60 shipped... Let me know
Old Mar 24, 2014 | 07:12 AM
Thanks for the replies guys I guess I should have looked a little better first. So should I get 7.300 or 7.325?
Old Mar 31, 2014 | 04:09 PM
codyseals's Avatar
Seen this and really want to know how you got that formula? New to this and really eager to learn all these formulas so I don't rely on keyboard ninjas in forums.
Old Mar 31, 2014 | 04:30 PM
Darkman's Avatar
https://ls1tech.com/forums/12843999-post7.html
https://ls1tech.com/forums/12529924-post3.html
https://ls1tech.com/forums/generatio...s-measure.html
Old Mar 31, 2014 | 04:46 PM
Thanks for sharing "darkman" and for the record I went with 7.300 comp pushrods and they worked out perfect
Old Mar 31, 2014 | 07:54 PM
codyseals's Avatar
Thanks man!
