Should I "Retard" my cam...
Old Mar 30, 2014 | 09:17 AM
Friggy's Avatar
Default Should I "Retard" my cam...
I am degreeing my cam and had a question on whether or not I should retard my cam or install straight up. Right now I have it degreed straight up and it is spot on what the cam card says. The only reason I'm asking is because I just ordered an S60 with 4.10 gears and was curious if I should shift the power a little more to the top due to the gearing? Just curious on what effects this might have on my setup and is it worth it. I know there is probably not one great answer, but any help would be appreciated?
Here's what I have:
LS1/T56, Stock 346 bottom end, 243 heads(hand ported), 230/238 - 600/603 112+3 cam, LS6 intake, long tube headers.
Old Mar 30, 2014 | 09:22 AM
KCS's Avatar
KCS
Moderator
Have you checked PTV? If you're tight on the exhaust, you may not really even have room to retard the cam.
Old Mar 30, 2014 | 10:12 AM
Friggy's Avatar
No haven't checked PTV. We thought about that last night. I guess I should throw a head on and check it.
But, assuming I have good PTV, is retarding the cam say 4* going to make a big enough difference to notice. I really don't know what effects each degree of retarding the cam has on the power and at what RPM range would it take effect.
Old Mar 30, 2014 | 10:25 AM
FEAR LS's Avatar
I wouldn't retard the cam if PTV clearance is good. You will love that combo! The six speed makes up for a lot of that gearing.
Old Mar 30, 2014 | 10:36 AM
KCS's Avatar
KCS
Moderator
It'll soften up the low end power and add more up top. I had my cam with a 235 intake duration on a 109ICL in my LS1, which will be similar as far as the IVC goes to what you're doing, and it did seem a little soft at lower RPM, but it was still fun. If it's going to see a lot of street miles, I'd leave it alone. Low RPM power in my opinion, is what makes a street car fun to drive.
Old Mar 30, 2014 | 10:44 AM
Friggy's Avatar
Yes, it is going to see mostly street miles. The only reason I was considering retarding it was due to the 4.10 gears. I was thinking I could afford to lose a little off the bottom with those gears, and shift the power a little higher up in the RPM range. I'll probably just end up leaving it. We're only talking a few degrees anyhow, and was just curious how big of a difference it would make and if it would be very noticeable.
Thanks for the input!
Old Mar 30, 2014 | 10:46 AM
HCI2000SS's Avatar
Right now you're a 109 ICL, and with a mid 230's duration...that's a good combo IMO! My worry would be if you retard it, it will be too much of a dog with that much duration
Old Mar 30, 2014 | 12:56 PM
Sales@Tick's Avatar
I would ask the person who spec'd your camshaft.
That cam IMO will pull fine to 6500-6700rpm.
Old Mar 30, 2014 | 04:35 PM
Kip Fabre's Avatar
(Should I "Retard" my cam...?)
NO. I am sure there is a cam running RETARDED in the engine that runs good but I have seen it. They all seem to run better a little on the + side.
Old Mar 31, 2014 | 05:50 PM
Friggy's Avatar
I don't know who spec'd it, but could probably find out if I really needed to.
But thanks for the advice guys. I think I will just leave it straight up. It does have advance built in, and I don't want to end up with unused power above my target RPM range. I also don't want to end up regretting it if I retard it, and from the opinions it sounds like leaving it is the best situation.
Thanks
Old Apr 1, 2014 | 08:52 PM
PREDATOR-Z's Avatar
Try factory ls6, they are 118 lsa on a 120 icl
