LS1 Spring retainer
if you are lucky enough to not have ptv contact, check for damage on valve stem, retainer, and old locks. if everything checks out, definitely replace rockers with a stronger set. then try try again... i looked up the specs and there isnt anything too crazy about those springs, unfortunately i think darkman might be right, it really does sound like ptv contact. good luck man!
When you get that rocker and spring off, get a photo of the guide and valve stem seal.
First busted stock rocker I've seen here. Maybe the retainer to guide clearance is all wrong. Or the spring went into complete coil bind for some reason.
Who put the heads together?
Ron
