Is my valve-train tearring up?
The engine was extensively modified +10 years ago.... ...these bits in the oil pan look like a valve-keeper and perhaps the metal piece of a valve stem seal....
mods include shaved ls6 heads, terra yellow roller rockers, double springs, hot cam, longer push-rods, double roller chain, high volume oil pump, etc....
this is a pic of the valve covers off..... I pulled one of the Terra-Yellow rocker arms off - no damage.
Should I just keep tearing it down?
....Not sure if I should take the heads off, if nothing is found up top????
If it were mine, I would to see the top of each valve to make sure everything is in place, so I would take off all the rocker arms.
That almost looks lifter related to me. I have seen the top sides of the lifter break off before. It also looks like the chunks came from something round. They look too big to be off the valves or keepers. If your rockers look fine, I would start looking a bit below them.
