370ci piston to deck height = .019?
Old Apr 21, 2014 | 11:02 PM
TX02ramair's Avatar
Default 370ci piston to deck height = .019?
Does it seem ok. Pistons 1-3-5-7 are out the hole at .019 and piston 2-4-6-8 pop up at .014?
Its seems to me that they pop up a little too high. pistons are mahle 4.030 Rods are scat I beams 6.125 Crankshaft is Gm from a ls1.
Old Apr 21, 2014 | 11:05 PM
KCS's Avatar
KCS
Moderator
Are you measuring the piston rock and averaging the numbers?
Old Apr 21, 2014 | 11:07 PM
TX02ramair's Avatar
Yes I did. Btw your input is appriciated guys.
**Edit** I did the method used in this book
[IMG] [/IMG]
Old Apr 21, 2014 | 11:12 PM
TX02ramair's Avatar
I also did use my ls1 main and rod bearings for measurement purposes. They look in ok condition.
Old Apr 22, 2014 | 02:21 AM
Burken01's Avatar
Iron block + decking it equals close to .020 piston out of the hole using a 6 1/4 rod typically..
Happened to me, was the block decked?
Old Apr 22, 2014 | 07:45 AM
TX02ramair's Avatar
I don't think so. Its a ATK seasoned lq4/lq9 bare block. From my understanding they just remove as little as possible from the deck just enough to resurface.
Old Apr 22, 2014 | 09:57 AM
intenseblue's Avatar
Im not a machinist but thae .005 difference per side doesnt sound right. Did ATKs paperwork mention the deck height? Any amount removed should be noted. Running a stock MLS gasket shouldnt be an issue and would leave you with room.
I just have this thought in my head of an engine coming from a top of the line shop with a perfect deck height and pistons on one side with a .005 taller compression height at .010 out one side and .005 out the other, realizing it, and running a .040 gsket on one side and a .045 on the other and it seems WAY out there. Just an idea of whats in my head. I'd have it checked out.
If that were my engine and a machine shop did the work they'd be correcting something before they got any cash.
Will it run? Sure. For a brand new engine though it needs to be right.
Old Apr 22, 2014 | 09:59 AM
Did you measure these? Bearings are a wear item and that should be taken into account. Missed that earlier. Good luck with build.
Old Apr 22, 2014 | 10:13 AM
TX02ramair's Avatar
No I didn't measure the bearings. But it did seem odd that all cylinders on the same side were out more than the other. Like you said it will run but since it will be a new engine just want to make things right.
Old Apr 22, 2014 | 10:16 AM
TX02ramair's Avatar
Can somebody point me to another method of checking piston deck height. A link or something.
Old Apr 22, 2014 | 10:27 AM
TX02ramair's Avatar
No it didn't have any note on the engine regarding deck height if im not mistaking.
Old Apr 22, 2014 | 01:24 PM
baronsmith98's Avatar
Are your pistons on the right side? I know the centerline of my wisecos are slightly offset to the thrust side of the motor and it would make a difference in the height of the rotating assembly but im thinking one side was decked too much. You shouldnt see that much difference.
Old Apr 22, 2014 | 02:25 PM
TX02ramair's Avatar
^^^Yes iam pretty sure their right. I don't know if mahle are offset but They have -4cc valve reliefs. So that made it easier. Do you think with new main and rod bearings would make a difference in the measurement.
Old Apr 22, 2014 | 03:39 PM
Bearings could have a minimal effect but seeing the difference of the height relative to passenger or driver side tells me it's the deck height. How did you check the deck height?
Old Apr 22, 2014 | 08:40 PM
A.R. Shale Targa's Avatar
When a machine shop just decks a block enough to make each side flat and have a nice RA finish to grab the gasket....they are just doing a quickie, pay me and get it out of here already type of job. This can typically cost between 125-150 bucks and perhaps is fine for a stock type rebuild. The correct way that a quality shop would do is to first measure both bank heights, surface the deck (bank) that's lower, and then make the higher bank match. It really just takes time and experience to get it right which can cost between 175-225 bucks. Hopefully the deck finish is accurate, both sides are flat, perpendicular to one another, and parallel to the crankshaft centerline. At this point you can correct it with different head gasket thicknesses but it's really kind of a crutch-fix that might just irritate you.
Old Apr 22, 2014 | 10:40 PM
TX02ramair's Avatar
Thank you all of you guys for helping. But what iam going to do next is get my crankshaft inspected and get a new set of main and rod bearings and balance the rotating assembly. Remeasure and figure out what can be done. I'll keep you guys updated on the reassembly.
