Ls1 intake swap to ls6 intake
Old Apr 22, 2014 | 11:42 AM
QuicksterZ's Avatar
Default Ls1 intake swap to ls6 intake
Im trying to figure out all the materials i need to do a ls1 intake to ls6 intake i have a 98 z28. I tried looking on internet i keep getting various different answers. From what i found i need this-
1. Ls6 intake of course
2. Ls6 coolant crossover pipe and rear blockoffs
3. Ls6 valley cover
If im missing anything else just let me know. Also if i have the ls6 valley cover would i need to have a catch can set up or either one without the other?While im in there would yall suggest anything else to replace or upgrade? Thanks in advance
Old Apr 22, 2014 | 02:02 PM
badtransam97's Avatar
Interested in doing this swap as well
Old Apr 22, 2014 | 04:01 PM
farmington's Avatar
U don't NEED the LS6 valley pan or the coolant tubes. You can use the LS1 tubes if you break off the fins on the bottom of the manifold that interfere.
Old Apr 22, 2014 | 07:21 PM
98RedZone's Avatar
Coolant crossover pipe and plugs
Pull the plastic connectors for the knock sensor wires off.
EGR blockoff plates if you dont have off road headers.
Old Apr 22, 2014 | 08:46 PM
Bama99z's Avatar
OP here is some info that I rounded up on this conversion, I hope it helps you out.
Old Style 01-03 LS6 Valley Pan Parts Needed
Description P/N Qty Valley Pan 12568002 1
Hose 12573109 1
5/16" Vacuum Cap 2
Valve Cover Plug 12568011 1
[COLOR="blue"]New Style 04 LS6 Valley Pan Parts Needed
Description P/N Qty
Valley Pan 12577927 1
Hose 12594779 1
Hose 12556454 1
5/16" Vacuum Cap 2
Valve Cover Plug 12568011 1[/COL
https://ls1tech.com/forums/generatio...y-cover-5.html
https://ls1tech.com/forums/generatio...sion-help.html
Old Apr 23, 2014 | 08:26 AM
Can you do the ls6 valley cover and retain the ls1 coolant lines,??
Old Apr 23, 2014 | 03:41 PM
wkeilC5's Avatar
On my 99 Vette I used a multiple tool and ground off the fins to allow the intake to fit over the ls1 coolant lines. No problem at all here
wkeilC5's Avatar
multi-tool
Old Apr 23, 2014 | 05:52 PM
TT427's Avatar
multi-tool
You used a hammer on your intake?
Old Apr 23, 2014 | 06:47 PM
Bama99z's Avatar
Man, I dont see why you can't. As mentioned above I think that you will have to clearence a few things for it.
Old Apr 23, 2014 | 08:15 PM
CHEVELLEPOSSE's Avatar
L you need is ls6 intake and block offs if you don't have headers
Old Apr 26, 2014 | 11:01 PM
QuicksterZ's Avatar
Is there a upside to using the "new " style ls6 valley cover than the "old" style? Also why would I pull the plastic connectors for the knock sensors off? Thanks for the info guys
Old Apr 28, 2014 | 11:59 AM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
This is what I did.
Old Apr 29, 2014 | 07:50 PM
skanknova's Avatar
A new oil pressure sending unit, if your not a rocket surgeon then your going to break the old one when your remove the ls1 intake
