Removing 317 Heads From Savana Van
Old Apr 24, 2014 | 12:57 AM
mapleridge's Avatar
Default Removing 317 Heads From Savana Van
Hi All,
just wondering if anyone can confirm if the heads can be removed from a Savana van from the inside with the interior cover removed.
Old Apr 24, 2014 | 06:14 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I had one of these vans.
Having the igloo cover makes working on these engines a breeze. You'll still need to do a lot of work from under the hood but heads can be swapped.
Pulling the engine-now that's a trick on these vans!
Old Apr 24, 2014 | 09:13 AM
mapleridge's Avatar
Thanks for the insight. just to clarify. There is work under the hood to pull the heads? I found an lq4 Savana in the junkyard. The block is extremely rusted and looks like a loss but I wanted to pull the heads for my build.
Old Apr 24, 2014 | 08:41 PM
Paul Bell's Avatar
OK so you're pulling heads off a van in a junkyard.
I guess you can be a bit more sloppy with yanking everything else off as you won't be re-assembling it all.
There will be some fasteners & that'll be easier to get to from under the hood.
Old Apr 24, 2014 | 09:32 PM
mapleridge's Avatar
ok. thanks. Yes. sloppy in the junkyard seems to be the best way.
Old Apr 24, 2014 | 09:53 PM
Paul Bell's Avatar
If the ignition coils are the round ones with the heat sinks, grab them along with the brackets and the attached bracket/coil harnesses.
Curious-what engine are these heads going on and what vehicle will get the engine?
Old Apr 25, 2014 | 01:10 AM
mapleridge's Avatar
lol. thats funny. I pulled those coils from an 03 tahoe and then decided against them when they said $30/coil at the junk yard. You think they are worth that price? I can check to see if this van has them. Do you need them?
I am thinking of putting them on my l59 and milling them down or keeping them as is for a future supercharger to lower compression. I might just mill down the 862's I have now. This build is for a BMW. I haven't cemented which chassis yet, though I am heavily leaning towards an e38 7 series. I am keeping my eyes open for a e39 5 series as well.
Old Apr 25, 2014 | 08:21 PM
BlackDuk98's Avatar
The 408 I am building now came from a 2003 Savanah from a local junk yard. Same 317 / coil setup. Complete engine, exhaust, wiring, computer and 4l80 for $245. $30 per coil is a joke. You can find clean 317's for $100, and the lowest I have ever seen was $35 for a set. The heat sink coils I have pulled from a 5.3 Silverado. You can find full sets of these d585 heat sink coils with brackets for a lot cheaper on tech.
I pulled the motor because the junk yard allowed me to bring in a sawzall and I chopped the entire front of the van off. Then used an a-frame to pull the engine out. As long as you pull the doors, fendrs and hood so the yard can still be able to sell them, you should be allowed to chop the rest off.
Old Apr 26, 2014 | 12:31 AM
mapleridge's Avatar
I don't think this yard allows a saw in but they have already removed most of the front end except the radiator and the support. I just want the heads. The block looks like a completely rusted piece. The heads are about $70. If I could get it cheaper on here I might not pull them.
