idle issue
Old Apr 29, 2014 | 08:15 PM
rpoz28's Avatar
Default idle issue
02 z28 idle drops to 400 then will go back up to 650. any ideas out there?
Old Apr 29, 2014 | 09:11 PM
Darkman's Avatar
You will probably get more responses in either PCM Diagnostics & Tuning or External sections. Assuming you are not throwing any codes (check engine light) I would start by check for vacuum leaks and cleaning the MAF with an MAF cleaner (e.g. CRC MAF cleaner).
