"eBay" Head Studs "How To" Video - Pro Comp - Alper
Old Jun 8, 2014 | 07:18 PM
  #41
BKsNHRA's Avatar
Originally Posted by chevybayboy
I also got the pro comps and used arp torque lube works great I only have mine torqued to 64lbs
If you plan to spray the car you might want to go to around 75. I had mine torqued around 65. Sprayed a 150 threw it and filled the crank case with water. New set of gaskets later they are now at 75 and doing just fine.
