The Vinci spring tool is the shit
Old May 17, 2004 | 08:11 AM
HumpinSS's Avatar
Default The Vinci spring tool is the ****
4 springs, seats retainers and seals in 15 minutes
For a 100 bucks who can beat that
Old May 17, 2004 | 08:27 AM
Scalpel's Avatar
I'm about to buy one for future use.
Old May 17, 2004 | 08:37 AM
1BADAIR's Avatar
Is that just like the new comp tool
Old May 17, 2004 | 08:38 AM
jmX's Avatar
jmX
Very nice!
Old May 17, 2004 | 09:30 AM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
It is the new comp tool. Vinci just sells it.
Old May 17, 2004 | 09:41 AM
Joe Vinci's Avatar
Thanks Humpin SS. Glad it worked for you. This is what we designed this tool for.
It is not the new comp tool, and I wasn't aware that comp made one.
Old May 17, 2004 | 09:46 AM
foff667's Avatar
LS1TECH Sponsor
comp makes one that is VERY similar to your design but more expensive FWIW
Old May 17, 2004 | 09:54 AM
apexman's Avatar
Looks good, but how good are the nuts? Do they last? I have used a tool simalar to that but for only one spring at a time. My problem was the nut would wear out (grade 8). Also, it would take a few trys to get the tool aligned correctly so the spring would go al the way down enough for my locks to pop out. Just asking as I will have to replace my springs eventually.
It looks like the groove cut in this particular tool would help keep the spring aligned properly when compressing.
Thanks,
Derek
Old May 17, 2004 | 10:36 AM
HumpinSS's Avatar
The grove side is for spring that sit higher. You need to use this side to get the nut started. Our first spring the nut started to wear but after we dropped in in some rear end oil everything was good to go
Old May 17, 2004 | 04:08 PM
Mark Campbell's Avatar
It is NOT the comp tool. It IS a tool developed jointly by Vinci High Performance and Crane Cams; and it is slick. Best thing available for changing springs on an F-body, really saves the back. Allows super fast spring changes other applications as well.
Old May 17, 2004 | 06:00 PM
Mike K.'s Avatar
Looks like a dual Larry tool, how much does that Vince one cost?
Old May 17, 2004 | 06:04 PM
HumpinSS's Avatar
106 shipped to MD
Old May 17, 2004 | 09:28 PM
marc_w's Avatar
haha... "dual larry tool".
I'm looking forward to using mine soon.
This Vinci one looks like the best I've seen. Cheaper than all of the 'fancier' spring tools too.
Old May 17, 2004 | 09:51 PM
OK so sue me I thought it was comp, looks very similar to the "Crane" tool.
Old May 17, 2004 | 10:44 PM
Mike K.'s Avatar
I could see how that tool could speed stuff up, I'll prob get one when/if my larry one breaks.
Old May 18, 2004 | 11:22 AM
P Mack's Avatar
The larry tool combined with an air ratchet was real fast. With that tool and an air ratchet you could probably swap all the springs in 15 minutes.
