Cracked ls1 block
A friend of mine took his 98 camaro to a local performance shop for a heads and cam swap. The shop had his car for three months. Once he got it back he swapped in an s60 rear end. He wasn't aware that the driveshaft had to be shortened and ran it with the stock driveshaft. After ~400 miles his engine block cracked on the highway. He began tearing the motor down and found that the coolant crossover tube was connected improperly. I believe its supposed to go from head to head, then into one side of the throttle body, then back into the radiator. He found that it was instead connected to the pcv line. The shop he took it to saw that he changed the rear end and are saying that that was the cause. The engine builders I spoke to say the trans would've gone long before the motor would, and that they've never heard of a rear end breaking a motor. I'm pretty confident that it was the shops fault, but I was wondering what you guys thought?
Thanks
Connecting the coolant crossover to the PCV system will send coolant to all the wrong places, the crank case and/or the intake.
Please tell us where the block was cracked. Pics would be very helpful.
After the work, any amount of running would've resulted in coolant beginning to fill the engine. Had the shop checked the oil level on the dipstick they would've caught it.
This is grounds to get any and all your monies back-including remove & install charges, all labor and any parts you or the shop provided.
Get a lawyer. Stand your ground.
I'm certain many of the enthusiasts on LS1tech can also do this job in just a few days.
