spark plug broke off in motor
so from previous experience's can it be rebuilt, or should i just look for a new short block and head.
also the cylinder wall seemed to have no damage some how.
As the cylinder wall aren't damaged, I'd say the block is fine.
BUT it looks like the spark plug went THROUGH the piston. You'll need to make sure it didn't do any damage inside the crank case.
If it's all fine underneath, heads & pistons is what's needed. You can use your block for the re-build.
New pistons and head. Might as well bump compression while putting in pistons or put on a different set of heads
A damaged block can probably be sleeved.
BUT... the rotating assembly is another story. The hole was punched in the piston by trapping the chunk of spark plug between the head and the piston. That transmits a lot of force down through the connecting rod and into the crank.
You'll probably have to replace the connecting rod. Have the crank checked for straightness. If it's a stock crank and it's not straight, replace it. Again, it can be repaired. But unless it's something special, why bother?
