use stock fuel injectors or bump up after mods?
So I'm doing and have done the following mods to our 99TA.
Circle D stall
New flexplate
LT headers
TSP cam
New springs
New timing chain
New hi flow oil pump
New lifters
Possibly under drive pulley
Should I use the stock injectors or bump them up?
Circle D stall
New flexplate
LT headers
TSP cam
New springs
New timing chain
New lifters
My bad its a TSP 224/228 .581/.588 112 LSA
Also how to determine the right size. Is there some form of calculation to determine.
I'd say this is a fueling question... but I'll let it slide in internal.
Without heads, you'll be just within the capability of the stock injectors. Once you add heads or if you step up to a bigger cam, you'll need more injector. Some 42s would be a good choice.
If you're absolutely DONE upgrading and are happy with everything, Ford Red Top 36# injectors and call it done.
If you ever plan on even a small 100 shot or heads, them grab the 42's
please move if needed, I figured since it was fuel related, it was internal, but if there is no future mods anytime soon or who knows if ever, am I hearing to bump up to 36# or is the consensus go to 42# so that no need to change later if more mods do come?
is there a part number? is it something I can get from the dealer since they are OEM? I just looked on summit and didn't see them, atleast doing just a generic search for fuel injectors, the ones I found for bosch came up for other cars nothing for mine.
We offer brand new 36#+ and also resizing and flowmatching services for less $$$ than a brand new set. The best thing on the resized are everything is new as far as o rings, filters and baskets and they are guaranteed good with verified spray pattern.
Let us know if we can be of any help!
