ls1 383 stroker ticking
Old May 16, 2014 | 10:18 AM
TA1999's Avatar
Default ls1 383 stroker ticking
HELLO TO ALL. I HAVE LS1 383 STROKER THAT I BUILT, IVE NEVER BUILT ONE BEFORE SO I DONT KNOW WHAT THERE SUPPOSE TO SOUND LIKE. AND I HERE TICKING COMING OUT OF THE TOP END I HAVE A MILD CAM ON IT BUT IT SOUNDS LIKE A DEISEL ENGINE PLEASE ANY HELP WOULD BE GREATLY APPRECIATED IM GOING TO TRY TO PUT THE VEDEO OF IT, AGAIN ANY HELP WOULD BE GRATLY APPRECIATED
Old May 16, 2014 | 10:30 AM
99z28383's Avatar
Did you check push rod length? All rocker arms torqued to spec?
Old May 16, 2014 | 10:39 AM
mikesimpalass's Avatar
Here is an old trick, put a timing light on one of your plug wires and let it flash. Your obviusly not checking the timing, so it doesnt matter what you flash the light against. If the light flashes at the same speed as the ticking noise, then its in your valvetrain. If the light flashes twice for every "tick", then its in the crank, rods, pistons, etc. hope this helps narrow it down.
Old May 16, 2014 | 12:44 PM
TA1999's Avatar
Quick question do i take the plug off and flash that plug , or leave plug on and flash which ever plug
Old May 16, 2014 | 12:58 PM
TA1999's Avatar
99z28383: MY BARE BLOCK WAS BUILT BY REVENGE POWER IN FORT LUDERDALE AND I BOUGHT A TRICKFLOW KIT WITH HEADS PUSHRODS AND ROCKER ARMS AND CAM AND SLAP IT ALL TOGETHER. DO YOU THINK MY PUSHRODS LENGTHS OR ROCKER ARMS ARE OFF?
Old May 16, 2014 | 01:15 PM
You can put the timing light on whatever plug wire you want. Leave all of them hooked up. Your just trying to get an idea if the noise is in the valvetrain or bottom end.
Old May 16, 2014 | 01:20 PM
The only way to be sure if you have the correct push rods is to measure them with a length checking tool. There are too many variables too guess; cam base circle, head gasket thickness, was the deck milled, just have to measure to be sure.
Old May 16, 2014 | 07:01 PM
TA1999's Avatar
thanks guys, looks like tomorrow ill be taking the valve train apart to check pushrod length. i did the timing light test and it was steady with the tick. o by the way the heads were shaved 5thausands now i know that does make a difrence on the length of the pushrod. thanks again, i will post to tell you guys how i made out. right now i have 7.5 pushrod length lets see tomorrow how much off a diffrence it will be.
Old May 17, 2014 | 09:34 AM
06Sierra2's Avatar
7.5 pushrods and a milled head? That pr sounds too long. You need to measure asap and let us know what u get
Old May 17, 2014 | 10:20 AM
Russ K's Avatar
The OP has Trickflow heads, and they require a 7.50 pushrod.
Sounds like excessive piston to bore clearance.
Russ Kemp
Old May 17, 2014 | 12:39 PM
TA1999's Avatar
Hey guys i measured with the pushrod checker and i got 7 1/4 so is a 1/4 in smaller than the 7.5 would you know how much is that in pushrod size
Old May 17, 2014 | 03:11 PM
06Sierra2's Avatar
Russ Kemp
My fault, I missed that.
Old May 20, 2014 | 01:00 PM
gagliano7's Avatar
7 1/4 would be 7.25
Old May 20, 2014 | 01:03 PM
gagliano7's Avatar
7 1/4 would be 7.25 . Don't forget to add in your preload.
Old May 20, 2014 | 01:28 PM
99z28383's Avatar
I don't know that having too long of pushrods would make the engine that noisy, it would just hang the valves open. Usually if your pushrods are too short and don't give the lifters enough preload is when you hear constant valvetrain tick.
But if you have 7.5's in there and you obviously need shorter, that issue needs to be addressed anyway.
