heads and cam now starter wont turn motor
I can turn it over by hand fine. The battery looks fine. The starter engages the fly wheel and that's it. When I check it the gear is still in the fly wheel. Im just wondering if from coolant spilling on it from changing the heads if it killed the starter.
Anything else I can check out?
