Daily driver cam, bolt-on 02 SS
Old May 19, 2014 | 03:12 PM
hooker2007's Avatar
Default Daily driver cam, bolt-on 02 SS
2002 Camaro SS
SS Induction Hood
Stock MAF
SLP lid + smooth bellows
Potz P+P throttle body
Stock LS6 intake
Stock 241 heads, injectors, internals...
Kooks longtube headers, offroad Y, open 3" cutout
Keeping everything else the same, what would a good daily driver cam look like? I want a noticable power increase and that chop sound, but I dont want to sacrifice driveability.
Old May 19, 2014 | 04:21 PM
Exeodus's Avatar
6 Speed or Auto?
Old May 19, 2014 | 05:01 PM
hooker2007's Avatar
Originally Posted by Exeodus
6 Speed or Auto?
6 speed!
With stock Hurst STS and traction control
Old May 19, 2014 | 07:01 PM
HCI2000SS's Avatar
You can get the chop sound from manipulating the exhaust, so you don't necessarily need a bigger cam. Maybe something like a 224 or 228
Old May 19, 2014 | 07:34 PM
hooker2007's Avatar
I want more power tho! At least 375 to the wheels and I want thr sound to turn heads.
Old May 19, 2014 | 07:44 PM
99z28383's Avatar
A 224 cam would get you to your power goal and on a 112 lsa be choppy enough to notice. A 228 with a good tune will also have decent street manners and out power the 224. It's all about how aggressive you're willing to go, just don't go with too small of a cam and start wishing you went larger.
Old May 19, 2014 | 07:47 PM
manzo81maro's Avatar
do you have to pass emissions/smog?
Old May 19, 2014 | 07:58 PM
Felix C's Avatar
220/220 220/224 see this https://ls1tech.com/forums/generatio...20-thread.html
Old May 19, 2014 | 08:08 PM
hooker2007's Avatar
Good advice! Considering a FUTURE heads upgrade should be part of the decision too.
Old May 19, 2014 | 08:09 PM
hooker2007's Avatar
In TX yes...
But no cat sooooo
I might have to pay for a sticker or tip the inspector.
Old May 20, 2014 | 12:50 AM
JakeFusion's Avatar
Super Hulk Smash
I'd do an EPS 226/234 113+2. Would make great power with the stock heads, be good for when you upgraded the heads, and would drive nice and sound cammed.
You'd be over 400rwhp with that cam.
Plus, I like the EPS lobes... endurance type so they are milder on the valvetrain and they use Cam Motion billet cores.
Old May 20, 2014 | 04:25 AM
That_Z28_Camaro's Avatar
I had the same goal in mind when choosing my setup and I couldn't be more pleased with the end result. Here's a link to my little build..https://ls1tech.com/forums/generatio...228r-241s.html
Old May 20, 2014 | 07:29 AM
hooker2007's Avatar
I guess I need to educate myself on specs too. Can anyone use lay terms to tell me what these #s translate to?
Old May 20, 2014 | 07:38 AM
1 Slow WS6's Avatar
228R is a great choice for an off the shelf cam. I had one and it put down 430/400 through a 12 bolt. It also had the same street manners as it was stock, its all in the tune.
Old May 20, 2014 | 12:53 PM
Sales@Tick's Avatar
I have a great 225/228 .612/.571 112+3 camshaft on the shelf. It works very well in a DD application, sounds great at idle and has plenty of grunt under the curve.
Pretty much in layman's terms it translates into a 4600-4800rpm torque peak and a 6000-6200rpm horsepower peak. Shift point of roughly 6500-6600rpm and an operating range from 2000-6500rpm.
Hope this helps.
Old May 21, 2014 | 11:01 PM
hooker2007's Avatar
Is head work mandatory?
How much does getting heads ported cost?
Old May 21, 2014 | 11:15 PM
Mavn's Avatar
"I MAID THEESE"
Nah, just get a cam and stall and roll peoples asses
Old May 22, 2014 | 06:17 AM
TeEnAgE pHeNoM's Avatar
Got some dyno results from a cam I did.
04 gto
Pacesetter 1 3/4 headers
3" exhaust (not sure on the quality of bends)
Cold air
Untouched heads, intake and tb
BTR springs
BTR pushrods
226/234 .615/.583 111+4 bullet cam
390rwhp/380rwtq
300rwtq@2500 Rpms
350rwtq@3000 Rpms
It peaked at 6200 and carried to 6500-6600 and they stopped the pull. It still had 300rwtq@6500 Rpms.
Very nice streetable cam and on very stable lobes that are great on valve springs.
Old May 22, 2014 | 06:37 AM
hooker2007's Avatar
So with the powerband sliding up, amd HP/TQ peaking higher, do you have issues shifting/cruising an low RPM?
This is for a DD, so realisically, ill nevet be over 3k rpm.
04 gto
Cold air
BTR springs
BTR pushrods
390rwhp/380rwtq
300rwtq@2500 Rpms
350rwtq@3000 Rpms
Old May 22, 2014 | 05:41 PM
99Bluz28's Avatar
I'd go with the TICK cam Martin suggested. With 2.5* of overlap you'll a clearly noticeable cam sound, but the overlap is still low enough it should DD nice!
Gears aren't required but I'd still recommend going with a set of 3.90 or 4.11 rear gears for more DD enjoyment!
http://www.tickperformance.com/tick-...1-ls6-engines/
