4.8 Build....Cam Swap
Hello, first I want to say that I'm 17 and I'm looking to do my first LS build. I've got an 2000 GMC Sierra single cab 4.8 2wd with 101,000 on it. This truck is clean and bone stock. I'm looking to do at least a cam swap, exhaust, and maybe a tune first to it so it'll sound bad when I drive it to school my senior year. I'm not looking to build a drag truck out of it, just a decent daily driver around 400hp. My question is, what would be a good cam to use that it wont loose bottom end, and that I can use with the stock valve train. I want the cam to hit hard and have a good choppy idle. I'm just unsure of how much lift I can push into the stock valve springs. I've seen guys using LS6 valve springs because you can get a set for next to nothing and they're good to .550 lift. I've been looking at a TSP 224/224 .581/.581 112Lsa cam. Would this work with the stock valve train? If not, what all would I have to do to ensure this cam works? Or is there any other better cams out there that'll give me what I'm looking for?
Let me know, Thanks
Let me know, Thanks
Let me know, Thanks
Let me know, Thanks
You are way way off base here.
Cammed 4.8l is going to lose lowend, smaller displacement makes a given cam act "bigger", you put a normal aftermarket 5.3l cam in it and the 4.8l will be more "peaky".
The fact you are considering reusing stock springs on an aftermarket cam says you are getting your info from decades outdated sources. I would sooner upgrade to aftermarket springs on a stock cam than run stock springs on an aftermarket cam.
The best advise anyone can give you now is forget the engine mods. Especially with a 4.8l things like gears and stall will be required first.
I did stupid stuff like putting a cam in my car with stock stall and such when I was younger, no need for you to repeat that mistake.
Let me know, Thanks
Let me know, Thanks
Are you going to continue to use your truck as a truck? If so, you need to read this to get a grasp of what the others are telling you. Compare cylinder pressure to torque/horsepower gains and losses at 2500 rpm and you will start to get the idea.
http://www.carcraft.com/techarticles...st_comparison/
Kip has some very nice drop in solutions for small displacement truck engines and if you want to keep stock springs they will be your ticket.
To get a choppy idle though you may have to go bigger and that will require valve springs and push rods.
If you're wanting to keep the stock stall converter I have done cams for 4.8 trucks with the stock stall and the biggest cam we've been able to get away with and still drive like stock is a 215/215.
Even that is on the big side for a 4.8 truck. I think a lot of people over cam these small engines. Especially in trucks.
