Starting to freshen up my old build, aiming for 460whp. Ideas?
About two years ago now, as I was full throttle, two of three cam gear bolts backed out and the gear spun off its normal axis, with one half-broken bolt holding it in. I had tried turning the car over a couple times after this happened as I was on the side of a busy street, the car just died at about 6000rpm or so.
I got her towed home, ripped apart, new bolts put in and everything back together, and she started up but the timing was way off. So now my plan is to drop the motor once I get my hoist up in my garage, and take the heads off.
Now this is where I need some opinions/advice. I have AFR 205s, and a custom grind cam. I want to go with a huge cam this year, and I wanted to replace the valvetrain anyways. This set up has about 40,000kms on it now.
If the heads are okay and just the valves are bent, I will just buy a full valvetrain/pushrod set up and make sure it works with whatever cam I want. But if the heads are screwed, I was told that if I sent them to get fixed and shaved down, then Im really limited to what cam I can use because of the higher compression.
So basically, I just want to know what you guys think I should do if the heads are fine, what should I get for new valves and springs, lifters and all that. And if the heads are NOT fine, I may end up just buying new AFR215s or something. I have about 3 grand to play with here.
I just want a reliable 460whp, opinions and ideas? Help me build me daily driven race car!
This has been its resting place for about a year now tired of seeing it just under a cover. Help!
Are you cool with flycutting at all? If so, even if your heads need to be milled down due to damage, then you can still run however big of a cam you want too and you'll be fine in regards to piston to valve clearance. If you refuse to flycut, and the heads are damaged, then it really just depends on how much they end up getting milled down to. Dr. Whigam on here ran AFR 205cc heads, milled down to 59cc, with a 230/236 112 LSA cam and didn't have any piston to valve clearance issues. With that said, I'm not sure he measured to see just how much clearance he had, so he may have been on the razors edge of what you would consider safe. Could you also define your definition of a huge cam? Huge cam, AFR 205cc heads, and piston to valve clearance don't exactly go hand in hand without flycutting. If I were you, I would have the heads milled in order to achieve around 12:1 compression, run a custom spec'd cam from someone like Ed Curtis at Flowtech Inductions, get a FAST 92 or 102 setup, and get the car tuned by someone who knows their ****. With those mods, you should be very close to, or possibly over, your 460 rwhp goal.
Moderator
I would sell it all as a longblock and buy a 370ci engine and ported OEM castings.
There's a good chance the heads need new valves, guides, and a valve job. The pistons could have gotten banged up if not destroyed, so you're probably in need of a shortblock anyways.
420whp seems pathetic with AFR heads, but hopefully it runs better than those numbers suggest. 460whp should be easy with more cubes and a decent set of OEM heads.
So if flycutting is something that is relatively easily accomplished, Ill probably go with what you said. Bigger intake mani, fixed heads, stronger valvetrain, and then a custom cam made to work with everything..
It is done using a special tool you can rent from guys on here. The tool cuts valve reliefs into the pistons to allow you moe clearance to run milled heads and a bigger cam. You won't get 460 without a FAST intake. No way the LS6 intake will be good enough to allow those heads to breath. Flycutting is not hard, based on what others have said, but I have no experience, so really can't say for sure. Everyone I know who has done it said they just took their time and it was cake.
The Scammer Hammer
FTI HellRaiser 229/239 .631.631 112+2 (That cam was spec'd for 241's and an LS6 intake. I'd personally get Ed to do something custom to really take advantage of the AFR's)
Unported Fast 92 Nick Williams 92
That's really it. TSP 1 7/8 and TSP duals, SLP lid, stock MAF (made 452 with stock MAF) trunion upgraded rockers, 7.4 pushrods...
My shortblock also had 145k miles when I did it. Could have made more possibly with fresher rings. Who knows. Maybe more with Cometic .040 gaskets. That would have been fly cutting time though I believe (which I'm not opposed to at all) it's easy. There's a good write up here, and JakeFushion just did it as well.
Check out the pistons and make sure the guides are good. If not, and you need valves, turn down some LS3's and throw em in and mill the heads. At least you know how far you "could" go...
Moderator
Moderator
And another...
463whp SAE with a stock LS2 intake manifold and throttle body. I think I recently saw one of these manifolds go for $150 in the Classifieds.
