Horsepower estimates?
Old May 22, 2014 | 01:08 AM
RikkiTorment's Avatar
Default Horsepower estimates?
I am installing Absolute Speed 5.3L Stage 2.5 heads, a pretty aggressive grind cam (MS3/MS4 aggressive), 55lb injectors, LS7 lifters, LS2 timing chain, Melling oil pump, Walbro 255 fuel pump and hardened pushrods.
Anyone have any rough estimates on what kind of numbers I will be putting to the ground?
Heads are Comp 977 springs 2.055- 1.575 valves, CNC'ed and hand finished, less than 1k miles on them.
Old May 22, 2014 | 11:45 PM
Nobody? D: Is 430-440rwhp way off?
Old May 22, 2014 | 11:59 PM
COSPEED2's Avatar
LS1Tech Sponsor
Those injectors are pretty large.
Id guess 430.
Although that depends on auto or manual etc.
We made 420 on a cam only 02 M6 ta. Our custom grind. Could put around a parking lot also. No need to go so aggressive for a number.
Old May 23, 2014 | 04:35 AM
Exidous's Avatar
Benchracing guess of 430whp/380rwtq
My 228 cam and 5.3L cnc heads made 420/375rw
Old May 23, 2014 | 03:43 PM
Id guess 430.
That is true, after getting the stats back from the machine shop on the springs. Keeping it around .600 lift will probably be best suited, something around the grind of a Futral F14.
Old May 23, 2014 | 03:49 PM
COSPEED2's Avatar
LS1Tech Sponsor
Lift doesnt has little to do with how aggressive or "large" a cam is. I like higher lobe lifts but the lobe itself is what is important and the specs together for each combo. It will run alright, but sometimes on ms3/4 cams and 5.3 heads you either have to recess the valves or flycut to fit the cam. Make sure you find that out!
Old May 23, 2014 | 04:01 PM
perfect.ta's Avatar
Go ahead ms4 is a nice cam
And no need to fly cut . 440 dyno jet 430 dyno mustang 420 dyno dynamix . Change your injectors though i see 42 . Will do a great job on low rpm ..
Old May 23, 2014 | 04:05 PM
madmike9396's Avatar
sounds like you need to do some more research.
is it a street strip car or strictly strip ?
You searching for a number or a good runner ?
Old May 23, 2014 | 05:07 PM
COSPEED2's Avatar
LS1Tech Sponsor
He would very likely need to flycut if using ms4 specs on 5.3 heads esp if they are milled any moren
Old May 24, 2014 | 02:32 AM
Change of plans after talking to my guy and getting the specs on my heads back... It is mostly a street, might see track time eventually.
Going with Lunati double springs and a custom grind around .227/.235 and .614/.621(might not go as high) on a 112lsa.
Old May 24, 2014 | 05:00 AM
COSPEED2's Avatar
LS1Tech Sponsor
Why are you so scared of lift? Duration and lsa will effect the outcome more than lift.
Old May 24, 2014 | 07:00 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The springs you are getting will more than handle the .600+.
That cam is a moderate cam that will have good midrange to top end with 7° of overlap.
Judging by your bolt-on numbers in your sig I would guess you still have a 3.42 rear that's stock too? You don't want a dog for a street car, and I would always check a set of heads for PTV especially if they were used prior. The whole "it will fit" internet line gets tossed around way too much. I can tell you all day on here that it will work just fine because at the end of the day I am not the one destroying my motor that I just bought a bunch of parts for. Check or have someone check it. Also, check your pushrod length too. Sometimes, not very often, a cam will have a different sized base circle and or the lifter may require something different and you may be better off running a 7.450 or vs. a stock length 7.400. This is just a for instance of course and it could be stock is fine or shorter. Again, the last thing you want is coilbind or PTV issues. Something to think about nonetheless though.
Lol, but to answer your question: It's hard to tell since you may not be sure on the cam you want. It will probably put you over 420rwhp and rwtq will depend on your grind, but I would not expect much over 400 if it even gets that high.
FWIW: I ran (YEARS AGO) a 244/248 .598/.598 115+2 cam on milled stock heads with a mild hand port and pulled 426/391. It was SLOW out of the hole on my stock rear but stupid on the top end.
Old May 24, 2014 | 10:56 AM
MikeWS6's Avatar
I think 440rwhp would be a good bet. My car did 423/386 on a mustang dyno with a 228 cam and 5.3 heads. I almost went ms3 but glad I didnt. The 228 cams rip down low.
Old May 24, 2014 | 11:26 AM
HCI2000SS's Avatar
OP, I gotta tell you...don't get hung up on the dyno numbers! Case in point: My ride made 420 rwhp n/a. On most other dynos it should be maybe 450-460 rwhp. Now here's the thing....it runs with 500 rwhp cars that weigh the same, have similar gearing, similar drivers, etc...My point is forget whatever number it makes, and go race it against other cars, and take it to the track as well
Old May 24, 2014 | 11:37 AM
Zmg00camaross's Avatar
My cam only m6 made 427 rwhp ran 10.86 at 126 mph. So I would think 440 rwhp is obtainable. But really who cares. Ppl are more impressed I think with my track times then my dyno numbers lol.
Old May 24, 2014 | 12:21 PM
Rise of the Phoenix's Avatar
I know I sure am. We are going to coordinate a day to go to the track together and I'm going to let you see what ET you can get with my car.
Old May 24, 2014 | 03:24 PM
My bad guys, I forgot to mention that I am doing 4.10's. I am just leaving everything in his hands at this point, stressing me out haha
But I am open to suggestions to throw his way.
Old May 24, 2014 | 09:40 PM
carolinaSS's Avatar
With injectors that big, are you planning on running a dry shot on it later?
Old May 24, 2014 | 10:29 PM
Just let me know man! Will get you ripping it!!
Old May 24, 2014 | 10:59 PM
M1SERY's Avatar
386whp and I flycut .095 on the in take side with the M4 heads were milled to 59 cc. I have rest of mods in signature,
